Author Topic: RNS 510 Firmware  (Read 76738 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: RNS 510 Firmware
« Reply #45 on: August 27, 2009, 10:32:46 am »
Just drive around for about 10 mins.
Be aware sometimes mine on startup thinks im in Germany till it gets a signal from the satellites (but usually within 5 seconds it is back to wherever i am )
Carl :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #46 on: August 27, 2009, 10:34:20 am »
The speed thing works but is in km/h.  :confused:
Are you using the speed reading in the TEST menu or are you looking at the Symbol on the map display??
It should be in MPH on the map display  :confused:
Carl  :happy2:
« Reply #47 on: August 27, 2009, 10:35:59 am »
Speed reading on map display.  :confused:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #48 on: August 27, 2009, 10:37:54 am »
Odd
It does MPH on mine
Have a play with it (the satnav dirty minded person  :P ) and see if it changes it?
Would be a good excuse for doing 50 in a 30 and 115 on the M'Way  :grin:
Blame VW and sue them  :grin: :grin: :grin:
Carl :happy2:
Offline CocoPops
    • Kennet Heath
« Reply #49 on: August 27, 2009, 11:04:30 am »
Just installing Nero to burn the image to CD.
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline CocoPops
    • Kennet Heath
« Reply #50 on: August 27, 2009, 11:31:20 am »
29% overall... appl 5%
30% overall... appl 14%
43mins to go....
Bit nerve wracking innit?!
60% overall... radio 25%
33mins to go...
« Last Edit: August 27, 2009, 11:45:26 am by CocoPops »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #51 on: August 27, 2009, 11:52:01 am »
No pressure eh  :pomppomp:
Stu...
Offline CocoPops
    • Kennet Heath
« Reply #52 on: August 27, 2009, 12:01:58 pm »
Summat like that  :grin:
Overall 77%... MPEG 29%
21mins to go....
Offline CocoPops
    • Kennet Heath
« Reply #53 on: August 27, 2009, 12:14:07 pm »
Done.....
Just rebooting.....
Offline CocoPops
    • Kennet Heath
« Reply #54 on: August 27, 2009, 12:25:58 pm »
Sorted  :congrats:
Can't see any differences yet lol
Although I do have the newer balance/fader options so it must have worked.
Offline CocoPops
    • Kennet Heath
« Reply #55 on: August 27, 2009, 12:32:43 pm »
So how do I show the "Version Info" as seen in Carl's pics?
« Reply #56 on: August 27, 2009, 12:38:18 pm »
Hidden menu. Reboot the unit and as it comes up hold setup (If i remember correctly).
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #57 on: August 27, 2009, 12:39:04 pm »
Don't you need to enable the hidden menu in VCDS now with the latest firmware?
Offline CocoPops
    • Kennet Heath
« Reply #58 on: August 27, 2009, 12:41:19 pm »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #59 on: August 27, 2009, 12:56:33 pm »
Yes the hidden menu needs to be enabled in VCDS as follows.
1. Go to Navigation - 37
2. Click on Adaptation - 10
3. Type 50 into the channel box.
4. Change the value from 0 to 1
5. Click on test and press code
6. Exit out of VCDS.
7. Press <> and brightness to reboot the rns-510.
8. Then press setup for about 20 to 30 seconds to enable the secret menu (just keep your finger on it it will go from normal menu to radio then after about 10-15 secs to the hidden menu)
Basically you can vew info like map version software version etc. You can even see your digital speed (in KM/H) in one of the menu's but it's no different to what is displayed on the speedo
Carl :happy2:
