Author Topic: Headlight washer replacement  (Read 936 times)
Offline madhoose
« on: August 23, 2013, 07:28:07 pm »
Had to remove the broken washer piston through the gap left when removing the fog light.
This was easy enough (apart from skint knuckles) as there was no washer jets attached, however I don't fancy trying to install the new one with jets the same way.
Does the bumper need to come off to do this job?
Offline mortygttdi
  • -Receive: 146
Re: Headlight washer replacement
« Reply #1 on: August 23, 2013, 09:39:39 pm »
Yes mate you'll need to get the bumper off has there is a bracket holding the washer jet on, you'll need to make sure its not damaged :happy2:
