Author Topic: Water Meth-making the most of Water meth Inj with a remap  (Read 5712 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Water Meth-making the most of Water meth Inj with a remap
« Reply #15 on: August 27, 2009, 04:24:56 pm »
Fair enough but have you considered an upgraded IC to keep your IAT lower and hopefully allowing a higher timing.
IMO lowering your boost to 7 or 8 may provide you with enough leeway to up the timing a notch as you'll then need "less" IC cooling for the same air charge plus your now higher fueling will help with lowering your IATs.
I have an S3 Intercooler so thats not a problem
To be honest 282bhp & 331lb/ft is enough  :wink: so im happy with the settings
Carl :happy2:
