February 17, 2025, 01:07:37 am
All Things Mk5
Mk5 General Area
Does batt get disconnected for cam follower replacement?
Topic: Does batt get disconnected for cam follower replacement? (Read 558 times)
Homer
Always Involved
-Given: 12
-Receive: 4
August 25, 2013, 05:08:58 pm »
Am going to get this done shortly and I have a revo map, if the batt is disconnected it goes back to stock and then the hassle of getting someone to fix the settings. So just wanted to check before booking the job. Thanks.
Bow
Always Involved
-Given: 4
-Receive: 7
Re: Does batt get disconnected for cam follower replacement?
Reply #1 on:
August 25, 2013, 05:09:44 pm »
I never bothered to remove it just make sure you don't open doors whilst pump off
fab5freddy
Just look at my post count
-Given: 238
-Receive: 239
Reply #2 on:
August 25, 2013, 06:33:58 pm »
As above, no need disconnecting the battery, just make sure you don't open the drivers door during the process
Meallbhan
Always Involved
-Given: 2
-Receive: 1
Reply #3 on:
August 26, 2013, 04:09:09 pm »
Just open your drivers door window before you start then you can access the inside of the car without opening the door and priming the fuel pump.
All Things Mk5
Mk5 General Area
