Author Topic: Fitting a sub help  (Read 847 times)
Offline adgti
Fitting a sub help
« on: August 26, 2013, 10:33:13 pm »
How could I fit a sub to my mk5 golf I have a rcd510 one of these
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Fitting a sub help
« Reply #1 on: August 27, 2013, 07:38:19 am »
Line out converter and an amplifier
Offline petesimcock
« Reply #2 on: August 27, 2013, 07:43:26 am »
Is there any way of using the existing amp if you have the soundpack fitted? Or can you fit one in its place to do the whole system?
Offline adgti
« Reply #3 on: August 27, 2013, 07:46:18 pm »
line out converter as in it uses the rear speakers?
Ryanedition30
« Reply #4 on: August 28, 2013, 10:06:08 am »
I had to use Line Out Converters on my RNS510.
Actually used the feed for the Front Speakers, as I believe the Rears are filtered.
Sounds awesome if you set it up Properly .
Ryan
