Author Topic: Variable valve timing  (Read 7662 times)
Offline veedubbubh
« on: August 26, 2009, 08:44:23 pm »
Hi people,
Simple question - does MKV GTI have variable valve timing - if so what kind and any other details would be helpful.
Many thanks.
WILLZIE
Re: Variable valve timing
« Reply #1 on: September 12, 2009, 02:50:05 pm »
Im sure it has, but only on 1 camshaft!
Offline veedubbubh
« Reply #2 on: September 13, 2009, 09:34:20 pm »
Thanx,
I am assuming its the Audi "valve-lift" type?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: September 14, 2009, 08:13:13 am »
this may be useful
http://www.golfmkv.com/forums/golfgoodies/mk5golfengine.pdf
as well as the general manuals that TT posted links to
TT links to various manual pages
hth  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline veedubbubh
« Reply #4 on: September 15, 2009, 12:18:34 am »
MKV GTI (original engine anyway) has - continuous variable valve timing on the intake camshaft which is turbo-related.
So now you know!!
Anyone available to explain that a bit better?  TT?
Thanks again.
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #5 on: September 18, 2009, 03:49:16 pm »
Thanx,
Nope.  The Audi 'valvelift' actually varies the 'lift' of the valve, ie, how far down into the combustion chamber they poke.  Our beloved Mk5s don't have any variable lift technology, nor does the Mk6.  It would seem that Audi are keeping their valvelift to themselves!
  • -Given: 88
  • -Receive: 95
« Reply #6 on: September 18, 2009, 03:51:34 pm »
So now you know!!
Thanks again.
Hmmmm . . . . the VVT on the inlet camshaft isnt turbo related at all.  It is simply controlled by the ECU map, and the actual timing is 'advanced' by oil pressure in a vane pump type of adjuster on the battery end of the engine.
Offline veedubbubh
« Reply #7 on: September 26, 2009, 07:49:42 pm »
Ok interesting - so when I step on the loud pedal its the ECU raising oil pressure to advance timing rather than a mechanical engineering advancement or have i got this all arseways?  :confused:
Just a general question when I have a few people reading this thread - do all direct injection engines use oil in normal use and are VAG engines different/better/worse in this respect?
Thank everyone for their info - much appreciated. :smiley: :happy2: :laugh:
  • -Given: 88
  • -Receive: 95
« Reply #8 on: October 20, 2009, 07:55:31 pm »
In a basic sence, that is correct!
Any engine can consume oil if they are not correctly run in - so it isn't unique to VAG engines
