Author Topic: Will a 2010 TSI GTI TB fit a 2005 TFSI GTI?  (Read 874 times)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« on: August 27, 2013, 02:05:25 pm »
My original part number is: 06F 133 062 G
And the 2010 one is: 06F 133 062 J
Only the last letter is different, should be all good, no?
Offline vRSAlex
  • -Receive: 253
Re: Will a 2010 TSI GTI TB fit a 2005 TFSI GTI?
« Reply #1 on: August 27, 2013, 02:23:05 pm »
It will, but it wont work if you have had a TB failure.  Needs to be Q at the end.
Follow AKS tuning on Facebook
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #2 on: August 27, 2013, 02:41:46 pm »
Why's that mate?
Would a 06F 133 062 G not work either?
I have VCDS...
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #3 on: August 28, 2013, 10:03:53 am »
Can anyone expand on what Alex has mentioned above?
The main reason in me not wanting to grab a brand new (not only because of the huge cost difference) but the fact that I'm not100% convinced the TB is dead.. Why?  Because I've read a lot of threads with this exact error code that wasnt solved with a new TB, they then went on to try 4x TBs, ECU, replace the wiring loom, the latter one only getting rid of the g187/188 code, on the original TB... So even though a new TB may solve this short term the updated wiring maintained the longevity; at least for those owners.
I plan on doing a full resistance check on all plugs and ecu, cleaning everything up, clearing fault codes, doing a TBA and seeing whether the faults reappear.
But the statement above has me questioning whether I cannot use anything but a Q variant which seems very odd... Unless this was said simply as the best one to use rather than you Cannot use any other versions...  Love to fully understand this.
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: August 28, 2013, 11:53:42 am »
I cant say the exact reason that using used or old TB's on a car that has the G188 fault wont work.  I have tried used ones that I know work and they come up with the same G188 fault as before.  Only was I've solved the fault is with a brand new Q TB (A used Q may work fine too).
There are two sensors in the side plastic of the TB, these are now a revised part on the Q TB's.
What exactly is the fault you have?  If its a G69 or G188 fault, then a new Q TB will cure it.  I have done 25+ TB's in the past year, with no Q versions going faulty in that time.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #5 on: August 30, 2013, 05:10:22 pm »
Found a low mileage Q version for £70, just fitted it, and it's green lights across the board after giving it a good 40 min run. :pomppomp:
Thanks for the suggestion Alex, hope it lasts. :happy2:
