Author Topic: Best way to get a spare key made?  (Read 656 times)
Offline Rumple
  • Das Original.
« on: August 29, 2013, 04:55:28 pm »
Whats the cheapest way to get a spare key together? Its a 2005 Mk5 golf gti  :happy2:
Black 3dr Edition 30 DSG
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Best way to get a spare key made?
« Reply #1 on: August 29, 2013, 05:18:39 pm »
Get the right blank key with the correct frequency, buy the rfid transponder chip, get the key cut and code it using vcds.
If you don't have vcds, borrow a friends.
All in mine came just under £40. I think at dealers its around £160.
Sent From My Samsung S3
Offline DAZ1985
« Reply #2 on: August 29, 2013, 06:33:26 pm »
I thought this was something that couldn't be done through vagcom as it requires a code which not even the dealers can give you these days.
How do you know what frequency the key is to be able to get a duplicate?
Tornado ED30 #673 stage1 map, miltek cat back, Sachs clutch, panel filter, WALK, eibach pro kit, s3 brakes all round
309bhp @fly
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: August 29, 2013, 06:46:45 pm »
You need the SKC code. The OP has a 2005 reg so can be easily read using vag commander. The frequency iirc is printed on the current remote fob when you take it apart.
