Author Topic: Error Codes  (Read 1364 times)
Offline zenicman9
Error Codes
« on: August 29, 2013, 06:15:14 pm »
Hey
I was hoping for some help stuck my car through a Code Reader and it's come back with 4 codes
DTC01 00532
DTC03 18049 -  Please check DTC Memory of Air Condition ECU (How can I fix this - As far as I am aware my golf doesn't even have air con)
DTC03 18051 - Please check DTC Memory of central electric ECU (How can I fix this)
DTC03 05536
Can anyone help?
Re: Error Codes
« Reply #1 on: August 29, 2013, 06:19:19 pm »
 :signLOL:
Why do you want to fix a code about air-con when you do not have it. You only need to fix things that are broken you cant fix air-con you don't have it.  :smiley:
If you disconnect the battery the car will throw loads of codes, it doesn't mean something needs fixing.
