Author Topic: Fitting a shorter number plate?  (Read 5332 times)
Offline Ant.W28LKR
  • Edinburgh
« on: August 29, 2013, 09:03:44 pm »
Hi, I have a couple of questions. First of all I have a gt tdi, now I have just got my private plate transferred onto the car. I'm wanting to fit a shorter plate on the front but when I removed the original plates, the registration plate holder that's fixed to the bumper has 4 big fixing points that will be clearly visible once I fit my new plate.  I went to VW today to buy a new plate holder (£26 btw) but its got the same fixing holes so I didn't bother with it.  The problem I'm having is that if I fit my shorter plate you will see the 4 big fixing holes of the original holder to the bumper at either side of my private plate.
So what's the easiest way around this? Has anybody else done away with the vw plate holder and fitted something else?
Offline gjseb16
Re: Fitting a shorter number plate?
« Reply #1 on: August 29, 2013, 09:09:18 pm »
this is mine shortened the plinth and filled holes mate and repainted
Offline chowgar
« Reply #2 on: August 29, 2013, 09:27:28 pm »
get a smoothed grill and bond magnets to the backs...
Offline G40will
« Reply #3 on: August 29, 2013, 09:44:23 pm »
US spec smooth GTI grille --- 1K0 853 651 H VW8
Then stick your plate on that or as above mentioned bond magnets.
Offline gjseb16
« Reply #4 on: August 29, 2013, 09:53:26 pm »
how much are these grills
Offline Veee-dubber
« Reply #5 on: August 29, 2013, 09:53:31 pm »
How much are they? is that from VW direct?
Ive always assumed people just smoothed theirs didnt realise you could buy a genuine part.
also, another option is sucker pads, cheaper and easier than the magnets.   :happy2:
Offline chowgar
« Reply #6 on: August 29, 2013, 10:12:09 pm »
got mine off here for about £50 :happy2:
  • -Receive: 427
« Reply #7 on: August 29, 2013, 10:22:49 pm »
I've got a American smoothed grill on mine and use both a magnet plate (kept in the boot if needed) and suction plate (on the car). USA grills are around £120 ish IIRC, plates and magnets/suckers are cheap as chips.
My OEM USA smoothed grill....
With my short number plate with double sided suction cups on.....
Offline Ant.W28LKR
  • Edinburgh
« Reply #8 on: August 29, 2013, 10:50:54 pm »
Guy's i have a GT TDI.
Do these smooth grille's only come in GTI versions?  If so it looks like my only other option would be to get it filled and painted.
Offline chowgar
« Reply #9 on: August 29, 2013, 11:07:57 pm »
filled and sprayed easiest and to be honest probably not that £££ at the body shop....
  • -Receive: 427
« Reply #10 on: August 29, 2013, 11:09:43 pm »
Vinyl wrap it or (as mentioned) get it done at a body shop. Can't see it costing more than £50 TBH.  :happy2:
Offline Veee-dubber
« Reply #11 on: August 30, 2013, 02:13:11 am »
As above, vinyl wrap it. Could fill the holes in with polygrip for all it matters, vinyl over the top and job done - smooth!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #12 on: August 30, 2013, 05:25:10 pm »
i just plugged the holes with domed fixings from b&q!
Red ED35 5dr DSG
BLOG | BUILD
Offline Ant.W28LKR
  • Edinburgh
« Reply #13 on: August 30, 2013, 11:14:12 pm »
How does it look?
