Author Topic: Ttrs brake fitting help.  (Read 2117 times)
Offline pd9264
« on: August 31, 2013, 05:51:13 pm »
Iv come across a problem fitting my ttrs brakes. On the near side front the original caliper has some wires on the brake pads. I took it there pad wear sensors. But my ttrs calipers have no wires on either of them on the pads. Can I just leave the electrical connecter with nothing plugged into it. Or will It give me a fault code or warning light.
Offline gazbutS3
Re: Ttrs brake fitting help.
« Reply #1 on: August 31, 2013, 06:01:29 pm »
you will get a low pad warning, what you could do is snip the old wires and connector from the old pads then connect the end of the wires. Plug the connector into the connector on the car and the car will think all is well. Cable tie the wires/connectors out of the way and job done :happy2:
« Reply #2 on: August 31, 2013, 06:03:45 pm »
It will give you a yellow pad waring light..Chop the connector of the pads and join the wires together
« Reply #3 on: August 31, 2013, 07:02:18 pm »
or if you have access to vcds then you could uncheck the pad wear monitor...
Offline pd9264
« Reply #4 on: August 31, 2013, 07:46:25 pm »
Cheers guys. Sounds simple enough. I never thought of chopping the old ones of the old calipers. Thanks. :happy2:
Offline valle
« Reply #5 on: October 29, 2013, 07:29:16 pm »
I will use this topic, if i can.
can someone plese tell me which hoses do i have to take , to get my audi ttrs calipers fitted to my mk5 gti?
thanks
« Reply #6 on: October 29, 2013, 07:38:50 pm »
thanks
Get in contact with DaveB1970 and he'll sort you out.   :smiley:
Offline valle
« Reply #7 on: November 05, 2013, 07:28:11 pm »
Still looking for parts.
no luck with member that u mentioned.
Offline matt g
« Reply #8 on: November 10, 2013, 06:10:52 pm »
Contact Hel directly they can custom make hoses
Offline valle
« Reply #9 on: November 11, 2013, 05:36:55 pm »
will fit hel hoses for rs3, on my mk5 gti ?
Offline matt g
« Reply #10 on: November 11, 2013, 07:28:36 pm »
I mention hel as they advised on another vw forum they can make custom hoses.
Offline valle
« Reply #11 on: November 19, 2013, 05:59:08 pm »
thanks
just one more/ last question
what is the difference between discs part numbers :
8J0 615 301 F  and 8J0 615 301 E
searching on ebay and found both part numbers...
Need for mk5
thansk
Offline Vasekk
    • OEMplus.eu
« Reply #12 on: November 19, 2013, 06:10:04 pm »
Get F ones. They are same just new revision. Should be more corrosion resistive.
Skoda Octavia VRS mk2 TFSI from Czech Republic powered by OEMplus.eu
Offline Vasekk
    • OEMplus.eu
« Reply #13 on: November 19, 2013, 06:11:52 pm »
According to hoses. Get TTRS/RS3 from Hel. Better to order with swivel fitting i like it more.
Offline valle
« Reply #14 on: November 19, 2013, 06:27:35 pm »
HEL lines are on the way, did like u told me.
And thanks for informations.
 :notworthy:
