Author Topic: ITG intake problem  (Read 1182 times)
Offline M7AXB
ITG intake problem
« on: September 03, 2013, 10:11:37 am »
Hi all,
Quickly tried to fit my ITG intake last night and ran into a couple of issues.
How do you get the heat sheild to fit? The instructions said about rubber grommets but, i don't seem to have them?
It also seems very tight at the 90 degree bend at the battery, is this normal?
Was missing a jubilee clip too so had to put the old intake back on until the new one arrives  :sad1:
Offline WHOZBOSS
Re: ITG intake problem
« Reply #1 on: September 03, 2013, 12:03:09 pm »
From what I've read you use the rubber grommets from under your engine cover.
Offline Christian1402
« Reply #2 on: September 03, 2013, 12:21:32 pm »
Yeah just use your rubber ones from the oem engine cover mate.
Offline H17YD_L
« Reply #3 on: September 03, 2013, 02:06:57 pm »
If you have to undo the black plastic engine cover mounts, they have a nut on the underside so they will not undo without removing this first
S3 Sportback S-Tronic GONE... MK7 R on order
Offline M7AXB
« Reply #4 on: September 03, 2013, 03:55:32 pm »
Ah forgot about the rubber grommets attached to the engine cover, cheers :happy2:
Offline Markyed30
« Reply #5 on: September 03, 2013, 05:14:44 pm »
I chewed he'll out of mine till I eventually realised the nuts underneath as the front 2 just screw in  :fighting:
Offline H17YD_L
« Reply #6 on: September 03, 2013, 09:21:56 pm »
I found out the same way. I thought no way theses can be this tight lol
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #7 on: September 04, 2013, 01:35:16 pm »
I thought exactly the same when i fitted mine but everyones seems the same :jumpmove:
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
