Author Topic: Car wont start need help!!  (Read 4786 times)
Offline jameelno1
  • TDI Power
« on: September 03, 2013, 01:06:53 pm »
the traction control light and esp light  when these come on the car doesn't start i have to turn the car on and off a number of times until they don't come on to start the car. ive checked the battery thats fine as its new. could it be a relay at fault or far worse?
golf mk5 1.9 tdi
Offline W8 Performance
  • Trader - 2014
  • -Given: 19
  • -Receive: 29
Re: Car wont start need help!!
« Reply #1 on: September 03, 2013, 04:25:34 pm »
Get it scanned if you can and see what comes up. I found this online
http://forums.tdiclub.com/showthread.php?t=381430
Good Luck
Offline jameelno1
  • TDI Power
« Reply #2 on: September 04, 2013, 09:28:43 pm »
Hooked it up to vagcom I had quite a lot of fault code one that stood out was 1314 and another sumat to do with g85
golf mk5 1.9 tdi
« Reply #3 on: September 04, 2013, 09:41:25 pm »
I know you say your battery is new but IMO you need to check what voltage it's putting out as something could have drained it.
Offline jameelno1
  • TDI Power
« Reply #4 on: September 05, 2013, 12:44:09 am »
Right here's the actual vagcom log hopefully someone can shed some light on the issues I have:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC 5645
Shop #: WSC 01287 785 00200
VCID: 22405DE2FDD4D03
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021121
VCID: 3A7085827544B83
2 Faults Found
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 CB
Component: Climatic PQ35 080 0201
Shop #: WSC 00000 000 00000
VCID: 66C801F2517CEC3
1 Fault Found
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000444002
Coding: 00890F0600041800001400001400000000
VCID: 37769CB64656A5B
Subsystem 1 - Part No: 1K2 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
4 Faults Found
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
010 - Open or Short to Plus - Intermittent
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 950 L
Component: KOMBIINSTRUMENT VDD 3554
Coding: 0001401
Shop #: WSC 00578 210 64257
VCID: 3162A2AEA8327BB
1 Fault Found
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.2 1202
VCID: 2E58B9D2B90C643
2 Faults Found
Freeze Frame:
Mileage: 520 km
Temperature: 23.0°C
Voltage: 12.00 V
Voltage: 11.80 V
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Mileage: 1480 km
Count: 0
Steering Angle: 1.40°
golf mk5 1.9 tdi
Offline mk4gti-t
  • -Given: 61
« Reply #5 on: September 05, 2013, 10:42:23 pm »
Sounds like a power issue. Have you checked all the fuses? Under bonnet fuse box and the one on the right hand side of the dash. Other than that it could possibly be an issue with your ecu itself  :sad1: I had a similar error recently and had to replace ecu and instrument cluster. Try clearing all the error codes and re-scan to see what is still there. Hope this helps and good luck!
