Author Topic: Engine workshop (bad starting) g28 sensor  (Read 1432 times)
Offline Robsta
« on: September 03, 2013, 04:57:30 pm »
Hi Guys
Last couple of days my 2005 gt tdi has been hard to start & has glowplug light flashing.
Tested with vcds & came up with the following:
16706 Engine speed sensor (g28)
P0322-000- no signal- MIL ON
03:ABS Brakes
Component front mk60. 0103
Coding 0023170
My questions are is it just the speed sensor I change & where the hell is it, also is it easy to change?
Any help is appreciated as my car takes a while to crank over & is doing my head in.
Cheers lads
Offline Robsta
Re: Engine workshop (bad starting) g28 sensor
« Reply #1 on: September 03, 2013, 06:08:48 pm »
Hi All
Have come across some more info, g28 is crankshaft sensor.
If so where the heck is that on the engine & is it easy to replace & will it need coding??
Cheers Rob
Offline doylebros
« Reply #2 on: September 03, 2013, 06:32:43 pm »
Offline Robsta
« Reply #3 on: September 03, 2013, 07:49:25 pm »
Hi
That info does not tell me where it is?
