Author Topic: Help! Can't open bonnet  (Read 2363 times)
Offline taylor
« on: September 04, 2013, 07:18:26 pm »
Come to check oil levels today, popped my bonnet went to the front and tried to lift my bonnet and it wouldn't open!
Anyone experienced this before?
Niall
Tornado red ED30
Offline Bow
Re: Help! Can't open bonnet
« Reply #1 on: September 04, 2013, 07:24:43 pm »
Yeah common fault mate. Very fiddly to get it open. Remove badge then you will need a thin long screwdriver with end bent over like a hook. You will see inside where badge is where you go through to hook vable
Offline taylor
« Reply #2 on: September 04, 2013, 07:28:42 pm »
Ok thanks mate then after I've done this what is the fix? Take it to vw or is it easy to fix yourself?
Tornado red ED30
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: September 04, 2013, 08:14:50 pm »
Dead easy fix. New bonnet catch mechanism at around £40-£50 (can't remember) and no more than 30 minutes to fit.
http://www.mk5golfgti.co.uk/forum/index.php/topic,55146.0.html
Offline Bow
« Reply #4 on: September 04, 2013, 09:13:15 pm »
Might not be broken the cable is a two piece . Mine had popped out where the two meet so popped back together and cable tied so it couldn't happen again
Offline taylor
« Reply #5 on: September 04, 2013, 09:43:03 pm »
Cheers mate appreciate it
Tornado red ED30
Offline Bow
« Reply #6 on: September 05, 2013, 07:58:16 am »
No Worries mate hope you get it sorted. Defo fiddly oh when pulling cable with the screw driver gently push down on bonnet. The two cables join on drivers side by the water bottle. Check that first
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #7 on: September 05, 2013, 09:23:28 am »
I've had the same problem and when I eventually opened the bonnet the catch was practically jammed solid.  I degreased it, re-lubricated it and it has been good for a year.  However, it seems to be sticking again now so a new one is probably on the cards.  Plastic ball within crappy - surprised how long its lasted!
Good luck.
Offline taylor
« Reply #8 on: September 05, 2013, 12:29:05 pm »
Thanks for the information lads
Tornado red ED30
