Author Topic: Airbag fault warning  (Read 763 times)
Offline sean76
« on: September 05, 2013, 10:32:46 am »
I've just connected my connect2 iPod lead into me stereo, put it all back together and now I'm getting an airbag fault warning on the dash. I haven't touched any other wiring anybody any ideas what the jells goin on
Cheers Sean.
Re: Airbag fault warning
« Reply #1 on: September 05, 2013, 11:01:59 am »
Did you turn on the ignition while the dash was disassembled?
If all the wiring is correctly secured then you'll need someone with vcds to delete the error.
Offline sean76
« Reply #2 on: September 05, 2013, 12:40:21 pm »
No ignition was off all the time. Dropped it at garage across from work to get it scanned
Offline raymondo1234
« Reply #3 on: September 05, 2013, 05:13:16 pm »
This very week i installed a dice to my mfd2, I stupidly turning on my ignition, momentarily forgetting i'd disconnected the airbag. No problem i thought, i've got a vagcom lead. Then I remembered I's sold it the week before. -(
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #4 on: September 05, 2013, 05:46:02 pm »
Unplugging the airbag light above the radio can sometimes do it
Offline sean76
« Reply #5 on: September 05, 2013, 09:09:09 pm »
Airbag de-activation warning lamp passenger side (k145)
Sporadic 009
Open or short to ground.
I might have dislodged the switch in the glove box that lets you turn it of or like the above post
Unplugging the airbag lamp on dash.
All sorted now though
Cheers sean
