Author Topic: Tyre issue.... anyone known this problem before  (Read 6664 times)
Re: Tyre issue.... anyone known this problem before
« Reply #15 on: August 29, 2009, 10:11:11 pm »
Out of interest what pressure(s) have you been using?
35 Psi front and back
So they are under inflated as well which wont help. :wink:
Phil Mcavity
« Reply #16 on: August 29, 2009, 10:17:20 pm »
I had a wheel wobble issue, which was cured after the Alloys were ment to be balanced by superTracker, but they made a complete hash and had a 100 ounce in-balance when they assured me "It couldnt possibly be the balancing when i went back to complain.
I then swoped fronts to rear and rears to the front, as it realised the newer pair i fitted were on the wrong axel. But what i think has amplified the problem now, is the tyres are now on the correct axel, but back to front or on the opposite sides as they should be.The fronts are most proberly the same!!. Problem is now, as the state of the inbalance of tread, the simply answer is completely change all 4 tyres for another Brand. Untill i have some funds (4 weeks or so) i will have to make do.
That means another £400 odd out of the pot that i wasnt expecting as these tyres still have half tread on them, my insurance is up in september, and was also hoping to Purchase a Down pipe and Cat to complete my mods. Gutted isnt the word right now. :mad:
« Last Edit: August 29, 2009, 10:20:21 pm by Phil Mcavity »
Phil Mcavity
« Reply #17 on: August 29, 2009, 10:17:43 pm »
What pressure do you recommend Ian?
Ifti
« Reply #18 on: August 29, 2009, 10:31:06 pm »
I usually have mine at 39psi - seem to get even tyre wear at that pressure.
I think the recommended is 2.6bar (as stated on fuel cap), which comes to around 37psi.
Phil Mcavity
« Reply #19 on: August 29, 2009, 10:34:01 pm »
if i am indeed under in-flated, wouldnt that cause the middle  of the tyre to wear more. Mine seems to be opposite :confused:
« Reply #20 on: August 29, 2009, 10:52:03 pm »
Underinflation causes the sides to wear, overinflation causes the center to wear
Offline keith
« Reply #21 on: August 29, 2009, 11:06:51 pm »
What made you fit Dunlops as replacements? I can recommend the  mitch ps2's
Feel for you though i had to buy two new fronts and pay the insurance all in the same month ouch!
Offline Janner_Sy
  • -Receive: 113
« Reply #22 on: August 29, 2009, 11:10:25 pm »
my car is a vRS, which to be fair is virtually the same car with some extra weight is reccommeded 2.2 bar rear 2 bar front on 18"wheels.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #23 on: August 29, 2009, 11:15:48 pm »
For sure my favourites.
Stu...
« Reply #24 on: August 29, 2009, 11:27:00 pm »
Neun und dreizig all round. :wink:
Offline QD MBE
  • -Receive: 102
« Reply #25 on: August 30, 2009, 12:22:47 am »
I am running at 41 all round.
 :happy2: :happy2:
Phil Mcavity
« Reply #26 on: August 30, 2009, 07:14:30 am »
ok speakie dee engleeessh?
Phil Mcavity
« Reply #27 on: August 30, 2009, 07:15:41 am »
cheers Dave, off up to the pump first thing :happy2:
Phil Mcavity
« Reply #28 on: August 30, 2009, 07:39:28 am »
oh dear 32 psi found all round :ashamed:, Now set at 41psi and already its made it quieter :happy2:
cheers Chaps
Offline BMX
« Reply #29 on: August 30, 2009, 08:54:38 am »
i think its called tyre scallops
"If Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
