Author Topic: GT TDi 140 or 170?  (Read 11642 times)
Offline AndrewJB
  • die gelbe Baron
Re: GT TDi 140 or 170?
« Reply #15 on: September 08, 2013, 09:30:23 am »
Both the CR140 and CR170 are good on MPG, not sure on the average difference between the two. If it was me i would go CR170 with DSG and then get it Stage2 DPF Delete by REVO
Offline GTI5
« Reply #16 on: September 08, 2013, 09:56:24 am »
Why not a GTI?
Doing less miles, more reason for a petrol - GTI ticks most boxes for most people!
Indeed.
OP - What's your mileage? If you commute by train to work I guess it won't be massive in which the case any saving by choosing a Diesel will be minimal.
Don't see the point of a 2.0l TDI to go to the local gym and shops.
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline prp74
  • -Receive: 126
« Reply #17 on: September 08, 2013, 01:48:35 pm »
I would defo recommend changing to the GTI. It will put a smile on your face every time.  :happy2:
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #18 on: September 08, 2013, 01:58:31 pm »
You'll get the most gains out of a 140 tdi as well
Not really a true statement
Stage2 DPF Delete is a real 215bhp on a PD170, PD140 is Hybrid to get above 220bhp IIRC
Both can go too 300bhp+ with a GTB turbo, Injectors and some engine work
A remap and exhaust will bring the 140 PD up to 190 bhp (35% increase).
Remap and exhaust on the 170 PD will give you 210-220bhp (23-29% increase).
Fairly simple maths. Plus torque increase will also be greater on the 140. :confused:
Offline AndrewJB
  • die gelbe Baron
« Reply #19 on: September 08, 2013, 02:18:45 pm »
When talking about overall % gained over OEM power then yes the PD140 will be more because it started lower and essentially with a GTB turbo kit the PD140 and PD170 produce similar final numbers
But i wouldn't buy a PD140 just because you can get 6% more overall power from OEM figures over the PD170.
If the buyers overall plan is to tune the car past stage 1 then i would get the PD170 simply because its peak figures will be better. if his plan is just to do Stage1 then i would get the PD140 simply because of the DPF issues on the PD170.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #20 on: September 08, 2013, 04:26:46 pm »
some really good points here peeps, thanks for the replies,
GTI will double my insurance and plus with my wife on the policy when she passes will increase it even further.
ill probably be doing around 50 miles a week,
only advantage i see of the 140 is the lower tax and insurance.
if i get the 170 surely an early model wont have the injector problems, and dpf could always be removed with a remap.
someone asked what mileage im on, im on 105k now
« Last Edit: September 13, 2013, 03:39:27 pm by vw55raz »
Offline AndrewJB
  • die gelbe Baron
« Reply #21 on: September 08, 2013, 04:34:20 pm »
its the other way round the earlier the 170 the more likely to have the bad injectors, i had a 58 which was one of the last and SEAT still replaced mine.
The new injectors also make the DPF worse
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #22 on: September 08, 2013, 04:39:53 pm »
Thanks,
What is the downside of a 140 then?  Weak turbo?
Offline AndrewJB
  • die gelbe Baron
« Reply #23 on: September 08, 2013, 04:42:09 pm »
Weak Turbo (IIRC) and porous head and 30bhp less
On the Leon at least dont know if the MK5 Golf is the same the 140 comes with 288mm brakes where as 170 comes with 312mm brakes aswell
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #24 on: September 08, 2013, 05:16:12 pm »
I have had both the 140 and 170 GT (currently have the latter) and personally prefer the GT 170 and apart from failed injectors the day after i bought it i've not had many serious issues with it. If you do go for a GT 170 try and get a 2008-2009 CR engine or ensure the injectors have been replaced under warranty.
Regarding the DPF. With your predicted mileage it would be worth having the DPF deleted otherwise it's just going to block.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #25 on: September 08, 2013, 07:14:55 pm »
Thanks mate that really helps .
I've still got a few weeks to decide what one to get, right now it seems the 170 and dpf remove.
Just seen matto's video of his car and there's a lot of smoke coming out lol. But I think he mentioned its due to the car over fuelling.
Offline GTI5
« Reply #26 on: September 08, 2013, 07:48:39 pm »
someone asked what mileage im on, im on 105k now and can hear the turbo wooing at low revs.
50 miles a week might give you DPF problems over time, you will probably end up driving around just to finish a regen after repeated short journeys.
A proper DPF delete is going to the cost the same as the extra cost to insure a GTI?
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #27 on: September 08, 2013, 08:09:44 pm »
If I only drove that much I'd be looking at an Electric Car, zero tax, no visits to the tax pump - shame they look sh!te but the Nissan Leaf is quite nice inside - slam it, 18's, remove the backseats for another half tonne of batteries and instant 300whp :signLOL:
Offline AdeMcG
« Reply #28 on: September 10, 2013, 06:58:40 pm »
A GT 170 all the way........
But then,....................... I would say that ......wouldn't I.................... :happy2: http://www.mk5golfgti.co.uk/forum/index.php/topic,70077.0.html
 :innocent: :happy2:
« Reply #29 on: September 10, 2013, 09:37:48 pm »
End of the day either cars the 140 OR the 170 have had issues.It all depends if and how far you are going to mod it and what power your after reallly
