Author Topic: Jetta boot pop....mod or not?!  (Read 2575 times)
Offline Jamminjim
« on: September 08, 2013, 12:22:51 pm »
If any Jetta owners out there can help me. Had my car for about a year now and mabey ten out of a thousand times my boot has completly opened when I've held down the boot release button on my keys.....so the question is are my struts just knackered or was I just lucky these few times?!
Would like to find out an upgraded strut Mabey to replace mine so this ain't just a luck thing  :party:
Offline torque777
Re: Re: Jetta boot pop....mod or not?!
« Reply #1 on: September 08, 2013, 01:56:05 pm »
We also have a jetta and it does the same ...it opens more often on hot days from remote ...I also found it was slow opening at the top and I used to push it to fully opened till I heard a pop and I'd snapped s end off one gas strut ..I bought a genuine one from tps £30 and popped it on ..boot opens more on remote now so if I'd changed both I recon it would pop on remote every time just couldn't justify buying two lol
sent using my own fingers
Offline Jamminjim
« Reply #2 on: September 08, 2013, 04:25:24 pm »
Seems like it was ment to open this then....not sure I can justify sixty quid on two new struts tho (i won't force them either by the sounds of it!)
Might try a bit of lubrication and see how that goes!
Cheers for the reply  :smiley:
Offline torque777
« Reply #3 on: September 08, 2013, 06:50:01 pm »
No problem ..looks good when it does pop open ..try making sure the seal isn't sticking to boot either
Offline Stanipkiss
« Reply #4 on: September 08, 2013, 09:27:45 pm »
Just seen this guys.
This is worth knowing coz mine just opens a jar and I have to lift it open, not even in hot weather.
Everyone I know with a Passat get this full on boot opening with the key.
Offline torque777
« Reply #5 on: September 08, 2013, 09:41:56 pm »
If I open it then close it then press remote it flys open even faster
Offline fingerling
« Reply #6 on: September 13, 2013, 01:18:24 pm »
so do we need struts from a passat?
Offline torque777
« Reply #7 on: September 13, 2013, 05:33:56 pm »
I just fitted a new jetta one ..wish I had fitted two
