Author Topic: Coding new Gateway - help!  (Read 549 times)
Offline Wolfsburggti
« on: September 10, 2013, 08:35:53 pm »
So i have installed a new gateway, sourced through Eddie on here, as I have upgraded from an rcd300 to 310.  Managed to get it all installed (what a ball ache installing the gateway is) and then opened vcds to code the new gateway.
All i have done is ticked the relevant boxes in the installation list, going off what i had on the old gateway.
However, Vcds is saying the gateway is incorrectly coded and i have dash faults for airbag, rear left fog and reverse light.
I feel there is something obvious I'm missing when coding the new gateway.  Do I have to do something other than just tick the relevant boxes in the installation list??!!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Coding new Gateway - help!
« Reply #1 on: September 10, 2013, 08:40:02 pm »
Hi
You should have PMd me so I could assist earlier
1st you need to make sure you have a Workshop code entered on your VCDS
Coding Long coding tick the box for RHD
and check the installation list for either items missing or extra items that are ticked
clear faults
Cluster and Key coding
Location Great Yarmouth
« Reply #2 on: September 10, 2013, 08:56:54 pm »
Have PMd you!  Thanks :smiley:
