Author Topic: Oil Consumption GTI  (Read 17767 times)
Offline Parmo
  • I'm a dirty thief
Re: Oil Consumption GTI
« Reply #30 on: September 23, 2013, 08:57:48 pm »
It was using half litre before a week and I have drove 2k miles until they informed me we used cheap oil non vw spec. Since quantum longlife 3 an fourtron additive an oil filter changed a week ago I've drove it hard in D an S mode hard using the paddle shifts as well done few hundred miles no loss of oil
Offline Jonathon555
« Reply #31 on: September 23, 2013, 09:05:53 pm »
Sounds as though wrong spec oil was the problem .
What oil were you using to top up Asda ?
What were the supplying dealer thinking using cheap oil ?
Offline Parmo
  • I'm a dirty thief
« Reply #32 on: September 23, 2013, 09:08:03 pm »
I was using quantum longlife 3 5-30w the dealer was evans halshaw
Offline Jonathon555
« Reply #33 on: September 23, 2013, 09:14:10 pm »
Suprise that a reputable big national dealer would get it wrong. But i guess they would use what they have in stock, whatever the main franchise has in the barrell.
How much does the quantum cost for 5 ltrs ?
Sounds like they are looking after you ok, which is always the sign of a good dealer.
Offline GTI5
« Reply #34 on: September 23, 2013, 09:18:57 pm »
I have never heard of fourtron , should I be putting it in my car ?
Does it improve performance ?
Just read the above link
Is this like slik 50 or zx1 extra lube ?
Is it part of a vw service , or do I need to specify this ?
The approved oil has an additive package.
« Last Edit: September 23, 2013, 09:21:41 pm by GTI5 »
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline Jonathon555
« Reply #35 on: September 23, 2013, 09:25:25 pm »
Ok cheers
Last service i have used Mobil 1 EsP 507
In my other car i used carlube triple r vw spec 507
Will these both have the additives packs ?
Offline GTI5
« Reply #36 on: September 23, 2013, 09:29:51 pm »
I don't think they are looking after you that well if they tried to skank you with cheap oil...cutting corners immediately raises my suspicions.
Did they say what oil they used before changing it?
« Last Edit: September 23, 2013, 10:02:24 pm by GTI5 »
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline GTI5
« Reply #37 on: September 23, 2013, 09:31:54 pm »
Ok cheers
You can find the oil specs on those respective companies websites.
Loads of info here: http://www.opieoils.co.uk/
*No affiliation with Opie oils
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline Parmo
  • I'm a dirty thief
« Reply #38 on: September 23, 2013, 09:32:33 pm »
Unsure what to do next two schools thought potential damage done by incorrect oil used but if it's ok now do I stick or twist
Offline GTI5
« Reply #39 on: September 23, 2013, 09:50:05 pm »
The measurement of oil consumption should be within the procedures that VW specify, I don't recall the use of additives to alter consumption.
Speak to VWUK and see what they have to say.
EDIT - Just looked and seen that Evans Halshaw are not a VW dealer so they probably won't help as it's not a VW approved used car.
« Last Edit: September 23, 2013, 09:54:56 pm by GTI5 »
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline Jonathon555
« Reply #40 on: September 27, 2013, 07:33:47 pm »
Has the fourtron worked ? Has it improved performance ?
Offline Parmo
  • I'm a dirty thief
« Reply #41 on: September 27, 2013, 08:52:46 pm »
So far so good
Offline Jonathon555
« Reply #42 on: September 27, 2013, 10:05:57 pm »
So far so good
Keep us updated , that fortron sounds good
Offline Frodo-anni
  • -Receive: 45
« Reply #43 on: September 27, 2013, 10:14:01 pm »
The Castrol Edge FST 5w30 1L top up is £12 at Asda at the minute.  :happy2:
If unsure what oil your dealers use, just supply your own, you can get it cheaper at ECP. VW charge you for 5L, but the car takes 4.6L for a full change, so if you supply your own, you have 0.4L left to use for top ups.
mk5 GTI Edition 30 DSG No0391
Offline GTI5
« Reply #44 on: September 27, 2013, 11:06:20 pm »
I've looked at this product and it makes a number of claims and it doesn't say what's in the bottle on the website either?
Quote from an Opie Oils Aftermarket Oil Additives PDF:
http://www.opieoils.co.uk/pdfs/tech-articles/Aftermarket-oil-additives.pdf
Another common type of additive is the oil thickener. They may be sold as products to reduce oil consumption, stop smoke or stop leaks, which they may well do, but by thickening the oil, they are reducing the lubrication of the engine. These products are extremely thick petroleum based oils that when mixed with engine oil, increase the average thickness of the oil in the engine to something far thicker than recommended for that engine. Cars are designed to run on certain oil grades and if one of the thickeners is used with what would be the right grade of oil, the oil will be far to thick to provide a good level of protection.
Possible fob off by Dealer imo.
MK6 GTI Revo
MK5 GTI DSG - Gone
