Author Topic: yellow cupra k1, polish testing  (Read 62542 times)
Offline Adil
Re: yellow k1 - Air ride
« Reply #150 on: December 13, 2013, 10:21:55 pm »
color looks awesome, does your plate mean anything or just a short plate for style?
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
« Reply #151 on: December 14, 2013, 12:24:32 am »
It's my name j44kxe or jake
Tornado red ed30 #0728
Offline cuprajake
« Reply #152 on: December 14, 2013, 11:29:21 am »
bags and valves cleaned up.
need some new top nuts for the valves just to make them look nice, then on monday rear bags and rebuild kit will be ordered
also sorted out a digital gauge setup for the front of the car and started to buy bits to fabricate my controller.
jake
« Reply #153 on: December 14, 2013, 10:11:16 pm »
Your slowing down Jake,you wwould normally have these on by now :grin:
Offline cuprajake
« Reply #154 on: December 15, 2013, 08:35:05 am »
With it being a budget build and trying to keep it sub £600, I'm having to search for stuff
I've ordered all the parts for the control box now. So if they come before Christmas I'll make that.
Still to get though
Rear bags
Tank
Compressor
Pressure switch
Fuses and relay
Wood
Rebuild kit
So I'm half way there lol.
I want to be methodical this time run all the wires so it looks as factory as poss
Offline cuprajake
« Reply #155 on: December 17, 2013, 05:45:59 pm »
Well today saw the real start of the build,
id ordered a few bits off ebay, but todays spend was propper
accuair 3 gallon tank
110-145psi pressure switch
viair 380c compressor
air lift rar bags and brackets
two front strut rebuild kits
so with that little lot ordered i built the housing part of it
heres the main base and how it will sit in the wheel well
IMAG0843 by cuprajake1, on Flickr
IMAG0845 by cuprajake1, on Flickr
after that i made a mount for the valves
IMAG0851 by cuprajake1, on Flickr
this will sit on top with the valves underneath hidden away with only the four shreader valves sticking up, the whole thing will be covered in grey carpet
IMAG0855 by cuprajake1, on Flickr
IMAG0854 by cuprajake1, on Flickr
the plan is to have the tank at the back next to the rear panel, then the compressor on the right hand side
jake
Offline Joshy
« Reply #156 on: December 17, 2013, 07:11:09 pm »
Those valves look similar to the ones I used when I started my build on the corsa. They didn't seem to work for me unfortunately. They kept sticking shut and even after taking them apart they still wouldn't work. Hopefully you have better luck than me mate :)
Offline cuprajake
« Reply #157 on: December 17, 2013, 07:17:17 pm »
Time will tell
I used similar ones in the past with good results. So hopefully there ok.
Offline cuprajake
« Reply #158 on: December 18, 2013, 06:23:20 pm »
got a bit more done today,
fitted threaded bar to lift the valves up
IMAG0880 by cuprajake1, on Flickr
then made a switch box,
i bought an ali case and some switches, along with wire,
marked and drilled
IMAG0858 by cuprajake1, on Flickr
holes cut
IMAG0860 by cuprajake1, on Flickr
polished
IMAG0862 by cuprajake1, on Flickr
and built up
IMAG0876 by cuprajake1, on Flickr
IMAG0877 by cuprajake1, on Flickr
after that i set about my digital display, i stumbled upon a system called tyrepal, its a wireless tyre pressure system works over 100psi with a funky display
IMAG0881 by cuprajake1, on Flickr
its going in the side vent
clear front added
IMAG0887 by cuprajake1, on Flickr
done
IMAG0885 by cuprajake1, on Flickr
IMAG0882 by cuprajake1, on Flickr
jake
Offline Joshy
« Reply #159 on: December 18, 2013, 07:12:33 pm »
You could have bought an AVS switch box that looks like yours :P cracking effort though, it looks amazing so far mate. Going to definitely follow this build.
« Reply #160 on: December 18, 2013, 07:15:49 pm »
Any joy keeping the warning lights at bay for the LED tails?
Offline xjay1337
  • -Receive: 377
« Reply #161 on: December 18, 2013, 08:01:59 pm »
Like this Jake, smart one!  :love:
Offline cuprajake
« Reply #162 on: December 18, 2013, 08:57:34 pm »
The avs one didn't cost £10 lol. But you are right. Everything has to be imported so it's got $70 shipping on it right away.
Yes Mike not had one fault cost yet mate.
Cheers Jay. It's getting there slowly
Offline cuprajake
« Reply #163 on: December 19, 2013, 05:22:57 pm »
box of goodies turned up today
IMAG0903 by cuprajake1, on Flickr
rear bags, comp and tank
mocked up how it will sit in the boot
IMAG0891 by cuprajake1, on Flickr
then added my outer case to the cntrol unit wires
IMAG0899 by cuprajake1, on Flickr
still waiting on the pressure switch and the rebuild kit,
ive also wired the valves up, and then ran a bit of the pipe to the valves with tee's getting ready
im going to try and get the boot set up ready to bench test for leaks as soon as the compressor comes
jake
« Reply #164 on: December 19, 2013, 05:50:32 pm »
 :happy2: Did you use Resistors?
