Author Topic: yellow cupra k1, polish testing  (Read 62540 times)
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
Re: yellow k1 - Air ride
« Reply #165 on: December 19, 2013, 06:10:26 pm »
Nope ;) I used the old gulf bulb holders in line.  So I'll still get bulb light of one goes out ;)
Tornado red ed30 #0728
« Reply #166 on: December 19, 2013, 06:52:50 pm »
Might get in touch next spring when I get round to doing it  :happy2:
Offline cuprajake
« Reply #167 on: December 20, 2013, 01:02:59 pm »
done as much as i can now, stuck due to christmas post, pressure switch hasnt come so i cant bench test till after the new yr :(
but ive done the bulk
here it is
IMAG0905 by cuprajake1, on Flickr
IMAG0911 by cuprajake1, on Flickr
IMAG0909 by cuprajake1, on Flickr
all mounted, may still rotate the tank more depending on the size of the tank, once ive pressure tested i can then hare wire it in place,
these are the wireless senders for the pressure gauge up front, there attached to schreder valves so should i have an issuse i can still air each corner induvidually
IMAG0908 by cuprajake1, on Flickr
jake
Offline chrisr763
  • -Receive: 62
« Reply #168 on: December 20, 2013, 01:07:05 pm »
Very nice! Smart looking setup and for a very reasonable price. Have you done this before?  :wink:
Offline cuprajake
« Reply #169 on: December 20, 2013, 02:41:06 pm »
IMAG0918 by cuprajake1, on Flickr
IMAG0919 by cuprajake1, on Flickr
IMAG0920 by cuprajake1, on Flickr
jake
Offline cuprajake
« Reply #170 on: December 20, 2013, 05:21:35 pm »
electrics sorted
IMAG0933 by cuprajake1, on Flickr
IMAG0936 by cuprajake1, on Flickr
jake
Offline TommyR
  • -Receive: 20
  • Black Edition 30
« Reply #171 on: December 20, 2013, 06:26:25 pm »
Looking forward to see the finished product! :happy2:
Offline cuprajake
« Reply #172 on: January 03, 2014, 07:59:35 pm »
Just a small update. I've still not got the pressure switch so I'm stuck.
Today I quickly fit the blanks to the tank asw ell as the outlet and as a make shift fit a gauge on there where the switch goes.
I wanted to leak test the tank. So far so good. Pressure has held at 100psi for the last three hours. I'll see what it's like in the morning.
I've also Ordered an accuair speed switch as a controller instead of the switch box I made. Purely as I had birthday and Christmas money haha.
http://bagriders.com/modlab/products/SWITCHSPEED-CONTROLLER.html
Offline xjay1337
  • -Receive: 377
« Reply #173 on: January 03, 2014, 09:40:08 pm »
Nice one Jake :) looking forward to when it's all working.
Offline cuprajake
« Reply #174 on: January 04, 2014, 08:46:37 am »
Me too. Christmas wasted loads of time lol
Where do you have your remote.
Offline cuprajake
« Reply #175 on: January 09, 2014, 01:16:16 pm »
controller turned up, along with the rebuild kit and the pressure switch
so finished the panel
IMAG1059 by cuprajake1, on Flickr
accuair manifold will be here tomoz,
jake
Offline xjay1337
  • -Receive: 377
« Reply #176 on: January 09, 2014, 03:07:22 pm »
Looks really good jake impressed.
Gonna get tyres of my wheels asap and get them split down for you ;)
Offline cuprajake
« Reply #177 on: January 09, 2014, 05:23:07 pm »
cheers, let me know when your ready to send
also built the struts up
took the old bits off, then cleaned and greased the parts as they went back on
IMAG1062 by cuprajake1, on Flickr
IMAG1064 by cuprajake1, on Flickr
pic of the strut built up dint come out, crappy phone.
then a nice tnt driver brought me this
IMAG1067 by cuprajake1, on Flickr
tripple r composites splitter
the manifold is due tomorrow, then all i need is air line and i have pretty much everything i need to start installing it,
in the next week or so ill finish off my boot mount, and get the wire through to the door for the controller with a view to fitting it next weekend
jake
Offline cuprajake
« Reply #178 on: January 10, 2014, 02:18:40 pm »
had a change of heart with the controller, main reason being the wire has to go through the door but the leon uses the full lock block, no where for the wire to go
it would mean taking the door off, drilling a hole for the cable etc so i decided on a new location
IMAG1070 by cuprajake1, on Flickr
its the cup holder section under the mdf2
so i made a bracket, primed and painted
IMAG1068 by cuprajake1, on Flickr
this is the bracket in situe, i used foam tape under the bracket then bolted down, this wat we get no vibration. the steel is about 5mm thick lol
IMAG1085 by cuprajake1, on Flickr
and finally in its home..
IMAG1092 by cuprajake1, on Flickr
jake
Offline cuprajake
« Reply #179 on: January 10, 2014, 05:21:29 pm »
well propper pissed off right now,
today is the first chance i have been able to test the front struts after fitting the rebuild kit....guess what one leaks real bad, sold by an ed38 member whos also in the trade to me as working, it needs a new bag which is over £100
cant trust nobody!!!!!!
