Author Topic: engine cover/intake help  (Read 1950 times)
Offline gazbutS3
« on: August 31, 2009, 05:31:12 pm »
evenin all,
could somebody confirm if there should be an O-ring on the connection at the MAF end of the engine cover/intake were the 2 spring clips are please, had the cover off today to fit the catch can and noticed that there was no 0-ring, pretty sure there was one on my GTI and ED30, can't remember if there was one on the S3 and its got knocked off at sometime. Thanx :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: engine cover/intake help
« Reply #1 on: August 31, 2009, 05:33:44 pm »
There is one on mine, I remember seeing it on the pipe when I moved it in the garage earlier today  :smiley:
Offline gazbutS3
« Reply #2 on: August 31, 2009, 05:37:08 pm »
I'm sure there should be one on there otherwise it could suck air in after the MAF has already done its business, don't suppose you could have a quick look for the part number could you :smiley:
whats worrying is where has it gone, I took the turbo inlet pipe off to make sure it hadn't fallen in there :laugh:. The engine cover was designed by satan as a tool of torture :grin: Good excuse to get a full intake system :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: August 31, 2009, 05:48:03 pm »
Just checking now  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: August 31, 2009, 06:07:36 pm »
Ok, I can see it listed as a separate part  :confused:
Just to check I thing you mean the o-ring you can see here
I checked the part number of this intake pipe
And there is no o-ring listed just the pipe itself: -
[pdf]http://www.mk5golfgti.co.uk/forum/downloads/gazparts.pdf[/pdf]
Offline QD MBE
  • -Receive: 102
« Reply #5 on: August 31, 2009, 06:12:10 pm »
Defo one on mine.
Offline gazbutS3
« Reply #6 on: August 31, 2009, 06:19:58 pm »
cheers steve, thats a pain in the @rse, will ring the stealer tomorrow, don't fancy havin to buy the whole pipe though :scared:
Offline candy turbo
« Reply #7 on: September 01, 2009, 09:55:51 pm »
evenin all,
how did the catch can fitting go ? any tips or pics ?   cheers :happy2:
Offline gazbutS3
« Reply #8 on: September 01, 2009, 10:04:36 pm »
its a pretty straight forward job, no pics sorry. My std PCV had developed a slight leak so changing it can only be good. I fitted the catch can in front of the battery as there is less room on the S3, but it will need relocating if I fit an intake :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: September 01, 2009, 10:11:00 pm »
I've got a brand new pipe in the garage Gaz if it helps.
Stu...
Offline gazbutS3
« Reply #10 on: September 01, 2009, 10:13:28 pm »
I've ordered 1 now thanx Stu, you can't get the o-ring on its own, so its going to cost 20 odd quid just for an o-ring :smiley:, would like to know where the original 1 went though :scared:
