Author Topic: Wheel cleaner  (Read 5443 times)
Offline john a
    • The Veneers Cover Band
Re: Wheel cleaner
« Reply #15 on: September 26, 2013, 05:54:26 pm »
Dont forget Iron x or any iron removal product is not actually a wheel cleaner. They are an iron contamination removal product.
The plan is to clean and seal the wheels - then only clean them with regular shampoo.  Ive never touched my wheels since theyve been on (3 moths+) with either iron x or a wheel cleaner..
This
I've started using AutoSmart Smart Wheels. I think AS recommend a dilution ratio of 1:3 but I use it at 1:10 with good results. At that dilution, it's LSP safe too (at least IME).
Offline wacky
  • -Given: 56
Re: Wheel cleaner
« Reply #16 on: September 26, 2013, 08:10:29 pm »
Offline xjay1337
  • -Receive: 377
Re: Wheel cleaner
« Reply #17 on: September 26, 2013, 08:14:43 pm »
Poorboys wheel sealant is not very good at all.
The durability is very poor.
The only plus is that it smells nice.. which when using a product for a job isn't what I look for.
FK1000p or Collinite 476s are far, far better choices and £ for lb, cheaper.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Wheel cleaner
« Reply #18 on: September 26, 2013, 09:34:20 pm »
IME Fk1000p is a really really excellent sealant.
'07 Red manual
Offline john a
Wheel cleaner
« Reply #19 on: September 26, 2013, 10:26:54 pm »
476s is very durable but I don't think it's heat resistant and I stopped using it on wheels after it started to yellow. I thought the lacquer had discoloured but normal service resumed after they were stripped back and resealed.
Offline xjay1337
  • -Receive: 377
Re: Wheel cleaner
« Reply #20 on: September 26, 2013, 10:30:49 pm »
I use it on my polished lips with no problem.
I will try to spot any yellowing that you mention but this could be polishing oils or other residues under the surface of your wax.
Thanks for sharing info though  :happy2:
Offline john a
Re: Wheel cleaner
« Reply #21 on: September 27, 2013, 05:33:38 am »
I'm pretty sure it was heat related as the yellowing was mostly around the centre of the wheels and not apparent towards the outer edges.
Offline csluyuan
Re: Wheel cleaner
« Reply #22 on: September 29, 2013, 10:40:18 am »
Thanks  :signLOL:
_________________________
Fifa 14 Ultimate Team Coins
Offline Rhys_Gti
Re: Wheel cleaner
« Reply #23 on: September 29, 2013, 05:19:19 pm »
Wax-tec fallout V2 I would recommend only £8 for 500ml bottle smells great and is the best iron removal product I have used. Once sealed then last awhile I only ever then need to use a more neutral balanced wheel cleaner if they become a little too dirty between washes.
Offline formulaclean
Re: Wheel cleaner
« Reply #24 on: September 30, 2013, 03:26:01 pm »
http://formulaclean.co.uk/wax-tec.php#!/~/product/category=5298517&id=22004981
thats the wax tec stuff, second how good this is! go for the V2 as the smell is 100x better!
Offline Paul_zx6r
Re: Wheel cleaner
« Reply #25 on: October 12, 2013, 11:18:31 am »
I seal with fk1000 then use billberry to clean them
Offline PhilNUK
  • -Given: 32
Re: Wheel cleaner
« Reply #26 on: October 14, 2013, 11:07:04 pm »
Bilberry Wheel Cleaner is amazing. Diluted right down it's very effective and works brilliantly.
Offline Leebo310
Re: Wheel cleaner
« Reply #27 on: October 15, 2013, 11:22:55 am »
+1 for this. Works out to be pretty cost effective too as it's relatively cheap to start with, plus as above you can dilute it down and it still works a treat!
55 plate GTI DSG / Revo remap / Miltek cat back exhaust / Evolution Motorsport Induction Kit / Sony XAV 62-BT head unit/ LED Rear numberplate lights
Offline ryan_w
Re: Wheel cleaner
« Reply #28 on: November 06, 2013, 12:46:32 pm »
Bilberry and Iron-X over here. Does the job a treat. Just don't let the Iron-X dry out!
