Author Topic: Stuck CDs  (Read 819 times)
Offline Meallbhan
Stuck CDs
« on: September 15, 2013, 01:09:22 pm »
Afternoon,
I fitted a new stereo the other day but I forgot to take all my cds out of the old stereo before removing  :stupid:  Its a rcd500, is there any way I can get all the cds out of it without the stereo being in the car?
I dont want to rip the dash apart again so I tried hooking the stereo up to a car battery charger with a + and a - but the stereo didnt light up.
Any ideas?
Offline Meallbhan
Re: Stuck CDs
« Reply #1 on: September 16, 2013, 06:23:43 pm »
Anyone??
Offline skard
  • -Receive: 245
Stuck CDs
« Reply #2 on: September 16, 2013, 06:51:42 pm »
I have adapted an old PC PSU to have 12v and ground outputs, I can externally start a stereo using a quadlock loom and crocodile clips - where did you get the 12v and did you ground the stereo at the same time?
Offline Meallbhan
Re: Stuck CDs
« Reply #3 on: September 16, 2013, 09:37:53 pm »
I have an old pc I could try that with, but whats a quadlock loom? I just used the red and black clips of the batt charger onto the earth pin on the stereo and the live. Thought it was worth a try. To connect to the stereo pins I used very narrow female crip spade connectors.
Offline skard
  • -Receive: 245
Re: Stuck CDs
« Reply #4 on: September 16, 2013, 09:44:51 pm »
Quadlock is the square plug on a mk5 stereo, but you don't need it if you have spades.
All I can think of is you may have connected to the wrong pins, or your booster isn't giving a consistent 12v?
You could always use the cigarette plug in the car somehow if it is just to spit out discs.
Offline Meallbhan
Re: Stuck CDs
« Reply #5 on: September 16, 2013, 10:41:27 pm »
Maybe I used the wrong pins? For the negative I used the stereo pin with the earth symbol and for the positive I used the pin marked +UB. The other pins are TEL MUTE, SAFE, CAN/L and CAN/H. These are on an rcd500.
Offline fingerling
Re: Stuck CDs
« Reply #6 on: September 17, 2013, 01:17:52 pm »
its probably easier to either 'write off' the CD's or take the dash apart, as trying to get it powered up without using a car could be asking for trouble ie you put too much power through it and knacker it
Offline Meallbhan
Re: Stuck CDs
« Reply #7 on: September 17, 2013, 09:36:23 pm »
I had wondered if I might damage it or maybe needed the gateway box connected to the stereo to make is work properly.
The dash may be coming off again at the weekend  :sad1:
Offline skard
  • -Receive: 245
Re: Stuck CDs
« Reply #8 on: September 19, 2013, 09:38:15 pm »
Just for reference, I tried again yesterday as I had my PSU out and the stereo definitely booted up with just a 12v and gnd via croc clips.
It'll be down to having a stable power supply I suppose.
