Author Topic: Emissions light not going away! Edition 30 mk 5 2007  (Read 1554 times)
Offline GTIEd30
« on: September 16, 2013, 05:33:44 pm »
Hi ppl
This issue has been going on since I bought the car a few months back but only now its started bugging me...
My emissions light keeps coming on.. i get it cleared and it comes back...i cant ignore it anymore as Im worries its gong to screw something else up
The diagnostic report is below..if anyone can help out I will be very grateful..I know the error is related to 'System Too Rich off Idle' but if the smaller details help in identifying the issue that will be great..many thanks:
VIN: WVWZZZ1KZ8W061023   Mileage: 74110km/46049miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G63N77QL
   Coding: 0403000318070060
   Shop #: WSC 01279 785 00200
   VCID: 37792FEF3A69
1 Fault Found:
008568 - Bank 1; System Too Rich off Idle
               P2178 - 002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 2
                    Fault Frequency: 27
                    Mileage: 73034 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:06:07
             Freeze Frame:
                    RPM: 2167 /min
                    Load: 63.1 %
                    Speed: 70.0 km/h
                    Temperature: 84.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   VCID: 73E1DBFF6E91
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 79FDE9D74CFD
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 01000007323253
   Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
   Shop #: WSC 01287 785 00200
   VCID: 71EDD1F7148D
   Subsystem 1 - Part No: 1K2 955 119 E
   Component: Wischer 050707 021  0501
   Coding: 00038805
   Shop #: WSC 01287
   Subsystem 2 - Part No: 1K0 955 559 AF
   Component: RLS     140707 046  0204
   Coding: 00208933
   Shop #: WSC 01287
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1BY1MW
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D753DC71855
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   VCID: 74E3D8E36B9F
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
            012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 964     HW: 1K6 920 964
   Component: KOMBIINSTRUMENT VDD 1214
   Revision: V0002000    Serial number: VWX7Z0G63N77QL
   Coding: 0003403
   Shop #: WSC 00413 210 186738
   VCID: F0EB54F39F87
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 090707F2002398
   Coding: 3D3F034007000003
   VCID: 2F69178FC239
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VDD 1214
   VCID: F0EB54F39F87
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         006 120B
   Coding: 0000692
   VCID: 387B2CD33777
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation
00096 - Drivers Door Central Locking (Safe) Motor (V161)
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 366722EB3D63
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 819002005103087F2D04840570085FC690FCA0
   VCID: 83010B3FBE31
   Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000692
   VCID: 397D29D70C7D
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 AD
   Component: Radio GR0       033 0033
   Revision: 0003303S    Serial number: VWZ2Z2G1903881
   Coding: 0040400
   VCID: 68DBBC932757
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1207
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
   VCID: 387B2CD33777
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Component: Tuer-SG         006 1201
   Coding: 0000144
   VCID: 397D29D70C7D
2 Faults Found:
00099 - Right Rear Central Locking (Safe) Motor (V164)
00931 - Locking Module for Central Locking; Rear Right (F223)
            008 - Implausible Signal - Intermittent
End   ---------------------------------------------------------------------
Offline GTIEd30
Re: Emissions light not going away! Edition 30 mk 5 2007
« Reply #1 on: September 17, 2013, 05:03:02 pm »
anybody my fellow GTI'ers?!   :jumpmove: :jumpmove: :jumpmove: :jumpmove: :jumpmove:
o
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
« Reply #2 on: September 17, 2013, 05:11:12 pm »
standard or tuned any mods?
Tornado red ed30 #0728
Offline GTIEd30
« Reply #3 on: September 17, 2013, 05:14:24 pm »
non at all, standard car. it comes up after around 50 miles...they I go turn it off..but now i think i need to do something before it gets worse...
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Offline cuprajake
« Reply #5 on: September 17, 2013, 05:27:12 pm »
when was it last serviced? plugs and filters done?
Offline GTIEd30
« Reply #6 on: September 23, 2013, 09:51:53 am »
hi guys aplogies for late reply, the 'show new replies' didnt show any new updates till i checked manually.
thank you for the link, the last service one in feb...has done a couple of thousand miles since..
I will ask a mechanic to check those bits in the link as I dont really have a clue.. I know someone said the maf sensor is a good start...might try to clean that perhaps...any advise?
