Author Topic: RCD/RNS 510 worth it  (Read 2717 times)
Offline DaveD
« on: September 16, 2013, 09:57:42 pm »
Looking to upgrade my RCD300 - the sound is terrible!
Are the RCD/RNS 510 systems worth the price, sound wise? Or would i be better going aftermarket?
Is the only difference between the RCD & RNS 510 the fact that the latter has sat nav? I don't need nav, so if the power output is the same i'd just go for the RCD.
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
Re: RCD/RNS 510 worth it
« Reply #1 on: September 17, 2013, 12:19:38 pm »
Just replaced my rcd300 for An RCD510 and sound quality is a lot better! What you'd expect from this type of headunit!
  • -Receive: 427
« Reply #2 on: September 17, 2013, 12:29:55 pm »
I've a RCD510 with an OEM Bluetooth fitted to it and it all works a treat. Get a decent SD card and you can play hundreds of albums at the touch of a button. All works via the Highline display/MFSW once coded.
Add a Mk6 climatronic unit and you'll be able to display your heated seat setting on the Headunit too!
RCD510 with Mk6 Climatronic unit. Looks like this on a Mk5/Mi6 when installed. Ignore the writting.....
Offline ianv5
« Reply #3 on: September 17, 2013, 01:39:32 pm »
Get an RCD510DAB, sounds good and gives you loads of additional channels!!!
Offline DANBOY66
  • -Given: 41
« Reply #4 on: September 18, 2013, 05:07:01 am »
I want this head unit in my mk5 when I find one I am also loving the mk6 upgrade
Dan..
Dan..
Offline cb81gti
« Reply #5 on: September 26, 2013, 11:09:57 pm »
so what do we need if we are swopping a RCD300 for RNS510?
Is it a direct swop?
I'm probably going to need a shark fin aerial as i don't have an aerial at all!
Offline Gman30
« Reply #6 on: September 27, 2013, 12:35:38 pm »
Depends what year your car is? I think if its a pre 07 car you will need to buy a new gateway and have it coded to your car otherwise you will suffer the battery drain issue.
Other than that they slot in the hole so to speak!
You will also need an adapter for the aerial connections or install a new aerial (Iv just put a DAB one on mine) - speak to DAB on wheels. very helpful and informative.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: September 27, 2013, 12:49:47 pm »
I have mine for sale here.
http://www.mk5golfgti.co.uk/forum/index.php?topic=73250.0
Its got the gps antenna,  and the fakra adapter too for the radio. All plug and play. No need to worry about canbus as the firmware ive just put on doesn't drain the battery.
Offline woahnowboys
« Reply #8 on: September 27, 2013, 01:47:23 pm »
I recently got an RCD510, with unlock code and FAKRA adapter for £150. It's the best mod I've done to the car so far, I love it :love:
I did require a canbus from Eddie_NL, for my 56 plate car.
It cost £75, and came the next day.
Works perfectly, and I'd seriously reccomend an RCD510.. Although the RNS looks even better if it's in your budget :happy2:
'87 MK1 Cabby - To be 20vT'd.
MK5 Daily.
Instagram - woahnowboys
