Author Topic: Gti 2007 not boosting hard  (Read 1199 times)
Offline raygti5
« on: September 18, 2013, 11:22:20 am »
hi guys
my car is not boosting hard but its boosting. the turbo is spooling and its dumping.. is there a simple test I can do to check whats going on?
I secured the induvtion kit properly and it feels slightly better as the previous owner did not even clamp it to the turbo!!
many thanx
Ray ( south Africa)
Offline mvb12
  • -Receive: 64
Re: Gti 2007 not boosting hard
« Reply #1 on: September 18, 2013, 11:32:01 am »
hi guys
many thanx
Ray ( south Africa)
Check the DV!
Smoke test it for leaks
Offline raygti5
« Reply #2 on: September 18, 2013, 11:58:00 am »
Hi
Ill def change that part this evening when I get home looks easy enough on the you tube clips  :happy2:
anything els u think I should have a look at?
was thinking of buying some decent spark pugs and oil aswell
Offline mvb12
  • -Receive: 64
« Reply #3 on: September 18, 2013, 12:02:39 pm »
Hi
check all your pipes are secure as you could be getting boost leak.
Offline raygti5
« Reply #4 on: September 18, 2013, 12:27:02 pm »
awsum will check them all..
ill take the dv off and clean it..if its stuffed then ill have to order it..hope its nothing serious
Offline MizGTi
« Reply #5 on: September 18, 2013, 03:45:06 pm »
Check what revision DV you have on the car at the moment. I had similar problems and changed the DV to a revision G and the car felt a lot better. I recommend you change the DV anyway its £39 from VW and you can probably change it yourself.
Offline raygti5
« Reply #6 on: September 19, 2013, 09:42:05 am »
i took it off and its cean as a whistle. took it into auto electrician so he can check it out. going to cal vw now
