Author Topic: Battery Draining  (Read 2407 times)
Offline MadDogMare
Battery Draining
« on: September 19, 2013, 04:16:31 am »
Hey
I've got a battery draining issue with my 2005/05 GT TDi. Original I thought it was just the battery, so got a new one... but turned out I had a faulty switch in the brake pedal that caused a brake light to come on at night(...?) (strip light on the spoiler above the rear window)... so, got that fixed. Couple of months later , guess what, battery totally drained again... had RAC test the alternator this time too and all is fine,  I've checked all lights (boot, cabiole, mirror and so forth) . After reading a couple of the threads on here I came to the conclusion that it might be the Can Gateway thing. Any advice?  :confused:
Re: Battery Draining
« Reply #1 on: September 19, 2013, 08:29:06 am »
Did you upgrade your factory head unit?
Offline MadDogMare
« Reply #2 on: September 19, 2013, 02:47:25 pm »
I have not upgraded or changed anything. As far as I'm concerned its standard as is. I don't know if the previous owner did anything...
Offline MadDogMare
« Reply #3 on: September 19, 2013, 05:01:15 pm »
Anything else you can think of? I'm totally out of Ideas... might have to take her to a auto electrician soon.
Offline madhoose
Re:
« Reply #4 on: September 25, 2013, 10:00:04 pm »
What radio is fitted? If it's one oh the newer ones that may be the cause
Offline TForrest94
« Reply #5 on: October 09, 2013, 12:33:40 pm »
I've had the same problem recently, thought it might be my sub so disconnected it had the battery and Alternator tested and everything was fine, got it booked in the garage Monday I'll let you know what they say if they come back with anything
Tommy
Its just a way of life.
Offline MadDogMare
Re:
« Reply #6 on: October 09, 2013, 01:04:30 pm »
No its still the original radio.
Offline MadDogMare
« Reply #7 on: October 09, 2013, 01:07:22 pm »
Tommy
Hi there Tommy.
Ive had the alternator tested too and all it fine, it has to be one of the systems draining... ill have to have mine booked in sometime soon too!
Offline Lollylauren
« Reply #8 on: October 09, 2013, 06:01:32 pm »
Try taking the fuse out for the radio if the drain goes then you know it's that . If not take one fuse out at a time and see which circuit has the drain on
Offline TForrest94
« Reply #9 on: October 10, 2013, 01:41:26 pm »
[/quote]
Hi there Tommy.
[/quote]
Has my golf since April and haven't had one problem, had a cambelt change and gave it a full service and within 4 days it happened, gotta carry a jump pack everywhere with me :fighting: not good when your in a rush
Offline doylebros
« Reply #10 on: October 10, 2013, 08:03:59 pm »
If it was me I would have the car scanned First - list of people with VCDS
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Then see if it's a module fault causing the issue.
Offline clivey
« Reply #11 on: November 19, 2013, 07:48:03 pm »
hey.
have edition 30 with battery drain also rns 510 radio fitted help
Offline doylebros
« Reply #12 on: November 19, 2013, 08:37:20 pm »
hey.
Have a read of this
http://www.mk5golfgti.co.uk/forum/index.php/topic,47405.msg589543.html#msg589543
Offline clivey
« Reply #13 on: November 19, 2013, 09:01:05 pm »
thank you very much will have a look :happy2:
Offline mvb12
  • -Receive: 64
« Reply #14 on: November 19, 2013, 09:35:31 pm »
I have a spare CAN GATEWAY can let it go for £40 squid.
PM if interested...  :popcornsoda:
