Author Topic: Retrofits, best places to do them or DIY?  (Read 2846 times)
Offline xjay1337
  • -Receive: 377
Re: Retrofits, best places to do them or DIY?
« Reply #15 on: September 19, 2013, 10:11:00 pm »
No you don't need it coded.
HOWEVER you will need Vagcom to code the new can gateway.
Vagcom can be picked up for £75 for non genuine (they work fine).
Offline edition30jmr
  • ED30
« Reply #16 on: September 20, 2013, 12:38:55 pm »
I've found one for sale it says that you don't need the can bus gateway part due to it being the new software version is this correct?
This is what he said: All wires and cables yes, no instructions or orig box you get everything you see in the pics as stated. It Came out of a 2008 car and worked fine in my 2004 mk5 golf with no battery drain for years
VW RNS 510 SAT NAV SYSTEM
GENUINE VW PART
VERSION A
2007
Taken out of my GOLF MK5 and in full working order when I removed it,this was only cos I changed my car.
What do you guys think will this just be plug and play?
Thanks Jay
Ed30 Beast!
« Reply #17 on: September 20, 2013, 01:29:01 pm »
Please don't endorse the use of non-genuine VCDS.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #18 on: September 20, 2013, 01:48:06 pm »
good to see you are supporting the original software / hardware developer.
Genuine vag com is cheap for what you get
Cluster and Key coding
Location Great Yarmouth
Offline LondonGT
Re:
« Reply #19 on: September 20, 2013, 01:49:21 pm »
I used Hazzydayz, did a great job and charge by the hour if you supply parts. Also when there was a tpms issue they came and spent ages sorting it with no issues at all.
I tried a few recommended people on here but guess they were busy as not one responded.
I got highline, mfsw, tpms and cruise done. Went with the kenwood unit in the end but have seen that fixing in a second hand unit isn't too tough.
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #20 on: September 20, 2013, 02:16:18 pm »
My ED30 is May 2007 , i put in a RNS510 which was brand new , it came from Lithuania or similar , it is the genuine article and cost me £600. It is simple to fit and i didn't need any Canbus update either . Eddie - NL is the one to go to . Don't bother with the MF buttons either , whats the point ? Everthing is within arms length anyway ! Cruise is a little more difficult and Eddie did mine  :smiley:
Offline xjay1337
  • -Receive: 377
« Reply #21 on: September 20, 2013, 04:38:15 pm »
People can use what they want and you and I can't force them!
I am not "endorsing" the use of it. I'm making a factual statement (that it works fine) and offering a different suggestion. I would recommend using Genuine VAGCOM as you get all the updates and latest codings as well as the support of Rosstech which is great but not everyone can afford £280.
 :indifferent:
Offline xjay1337
  • -Receive: 377
« Reply #22 on: September 20, 2013, 04:39:47 pm »
GENUINE VW PART
VERSION A
2007
Thanks Jay
Hi dude
As long as you have the radio code yes should plug straight in.
If you want the directions to show in your full height cluster then you'd need VAGCOM.
Also as the battery drain yes there is a certain version of Firmware that will negate the need to change the gateway.
If you do still get drain yes you would need to change the gateway however there is a bodge you can do with the fusebox for a temporary fix.
« Last Edit: September 20, 2013, 04:42:04 pm by xjay1337 »
« Reply #23 on: September 20, 2013, 05:09:27 pm »
No but they can be advised to either use a genuine lead or to contact a member that has one and is willing to help. There is a list on here in the VCDS section.
If everyone used non-genuine cables there would be no Ross Tech or the need for them to develop as VAG change their models then where would we be?
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #24 on: September 20, 2013, 07:51:25 pm »
well said m8 & you can pick up 2nd hand vcds from here or on the bay approx £150
Offline sanj
  • -Given: 17
« Reply #25 on: September 20, 2013, 08:43:49 pm »
Do it yourself mate.I did,spend some of that money on a genuine vagcom cable and code it all in yourself,my Edition30 is an early 2007 and did'nt need the a new can gateway,trust me the vagcom cable is worth every penny! :happy2:
  • ED30
« Reply #26 on: September 25, 2013, 05:21:03 pm »
Okay guys just saving for the rns510 and il install myself end of the month or just after!
Il have to upload some pics of my eddy and mods etc that have or will be done!
Thanks for all your help!
Jay
Ed30 Beast!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Re: Retrofits, best places to do them or DIY?
« Reply #27 on: September 25, 2013, 05:26:59 pm »
Jay
My rns will be up for sale soon
Sent From My Samsung S3
  • ED30
« Reply #28 on: September 25, 2013, 07:59:48 pm »
Jay
Give me a pm and when are you looking to sell it?
Jay
Ed30 Beast!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #29 on: September 25, 2013, 08:02:45 pm »
Will be removed this weekend from the car.
Ill pm you
