Author Topic: 'The' Arch Liner Screw Mod  (Read 8871 times)
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« on: September 20, 2013, 01:10:39 pm »
Guys,
Does the front wheel arch liner screw mod work exactly the same for other VW vehicles, in this case specifically the 8P Audi A3?
I'm on AP coilovers with 18x8 wheels and have just started to experience catching when turning at low speed on full lock.
What exactly do I need to do after I've removed the screw? In n00b mode I'm afraid  :ashamed:
Thanks.
Pete
Offline woahnowboys
Re: 'The' Arch Liner Screw Mod
« Reply #1 on: September 20, 2013, 08:14:29 pm »
Just feel around the outside edge of the arch liner, if there's one screw towards the top of the arch which is particularly obtrusive, take it out. Then you'll have to stop the arch liner sagging down. To do this, just push the arch liner up above the metal inside lip of the wing, and go for a drive :happy2:
'87 MK1 Cabby - To be 20vT'd.
MK5 Daily.
Instagram - woahnowboys
Offline sootpig
« Reply #2 on: September 20, 2013, 08:45:18 pm »
" just push the arch liner up above the metal inside lip of the wing,"
    If you do this you'll end up with rusting, corroded wings   :happy2:
Offline Simon_2.0t
« Reply #3 on: September 20, 2013, 10:06:48 pm »
Does this mod on mine mate.
About centre of the arch is a torq screw holding the arch liner in place. Unscrew this, take out the plastic nut thing behind it the screw goes into. Then making sure the arch liner is above it, push the lip up. It sticks out further than the rest of the arch so helps a bit.
Job done.
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #4 on: September 21, 2013, 12:07:38 am »
Thanks all  :happy2:
So, has someone measured the rusting risk after a lengthy period of time to absolutely known that rusting is a problem with this mod?  :scared:
Pete
Offline jonm
    • Staffs-VW
« Reply #5 on: August 13, 2016, 09:09:09 pm »
Thanks all  :happy2:
approx 4 months mine lasted before they rusted...
Offline jaffa
  • -Receive: 44
« Reply #6 on: August 13, 2016, 09:36:56 pm »
The screw mod shouldn't really cause the wing to rust
The rusting starts with the stupid sponge on the inside of the wing that holds water in
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: August 14, 2016, 01:43:37 am »
Leaving the arch liner where it is will cause more rust as the dirt and salt water sticks there so pushing the liner up will prevent the rust more than make it rust. I fit car up day in day out and have had some filth fall out of the liners.
Offline jaffa
  • -Receive: 44
« Reply #8 on: August 14, 2016, 10:49:49 am »
when i did the arch liner to do the screw mod/remove the sponge i ended up with a pile of dirt and leaves and a big sponge completely soaked with water and my wings were already rusted on the inside
if you want to see a rusty wing i can show mine but its because i rolled mine with a hammer and my tyre rubbing against it from being low
Finally after nearly 5 years iv got new wider wings from srstec to go on next week so no more rust  :signLOL:
Offline jonm
    • Staffs-VW
« Reply #9 on: August 04, 2017, 05:55:46 pm »
removed the sponges from mine and a year later I'm back where I started.... rusty
« Reply #10 on: August 04, 2017, 06:01:10 pm »
You can always trust rust...
..to never go away.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: August 04, 2017, 11:32:14 pm »
I have two freshly painted wings on without the sponges so let's see how long it lasts without rusting.
