So it has been a very long time since I have updated the build thread but I just have not had the time. Since the last post the project has taken another direct. I have decided to Forge the bottom end and go BBT K450 hybrid K04. It is a prototype turbo so don't really have many details yet but I believe it is based on their already successful K430x unit which so north of 440hp on rtech rollers so plenty of fun to be had. I'l see where this takes me and if I decided to go BT later on then most of the hard work has already been done.
I sold the CDL block and bought a used AXX block for a steal. I dismantled the block and dropped all the parts off at Ee Lye Racing in Runcorn as they are doing the bottom end build for me. I would love to have ago myself but I have never build an engine before and even with the aid of youtube and tons of tutorials I just can't risk something going wrong.
The block is getting hot washed, honed, and then painted before assembly beings.
The crank gear was an absolute bitch to get off as I did'nt have the VAG locking tool so made my own with an old crank pulley. Worked a treat.
And the end result
I kept the CDL head I removed from the block as it is in very good condition (only done 28K miles) and obviously has the better cams fitted. It is getting inspected and pressure tested, cleaned, walnut blasted, and skimmed before it gets fitted. A few of the bottom end parts, brackets, sump, etc are getting cleaned and painted the same colour as the block.
I decided to go with wossner pistons and ZRP rods from TSR performance as they have been proven to be a good package.
Here's a quick breakdown of the engine spec;
Wossner pistons 82.5mm
zrp rods (rifle drilled)
ACL Race bearings
1.8t oil pump conversion
ARP head bolt set
CDL cylinder head
I.E. valve cover
New block and head gasket/seal kits, water pump, timing belt, etc
Fluidampr crank pulley
1.8t oil filter housing with I.E. adapter plate to run a mocal oil cooler
Not a small list and that's not all of it. The block will hopefully be back by the end of the month and Ee Lye Racing are going to document and take pics for me so I will update you with the progress as it comes. Been waiting on the turbo for a good 6+ months now but I am aware it is a prototype and can understand they don't want to let it go out the door until it is 100%.
