Author Topic: Where to buy?  (Read 1370 times)
Offline jakex181
Where to buy?
« on: September 21, 2013, 01:36:02 pm »
Hi guys,
Just checked my PCV by removing the pipe on the manifold and blowing through it, there was no resistance at all so im guessing its failed. Where can i get a replacement part online? ive tried ECP but they dont have it. Also how can i check the DV as i understand this goes, is the only way to inspect it? Cheers
Offline jakex181
Re: Where to buy?
« Reply #1 on: September 21, 2013, 01:46:00 pm »
I have just checked it again using a different method by pulling the dip stick out and the engine idles rough which would indicate that the PCV is working so no need to purchase a new one. Still what is the best way to check the DV?
CHeers
Offline mvb12
  • -Receive: 64
Re: Where to buy?
« Reply #2 on: September 21, 2013, 04:20:16 pm »
Best places to purchase = Stealers or TPS.
Best way to check a failed DV = Take it out and have a look.
Offline jakex181
Re: Where to buy?
« Reply #3 on: September 22, 2013, 12:21:15 pm »
Thanks for the reply, after looking around online i think i do actually need to replace my PCV, i dnt have a vw or TPS near me so ive looked online and found this site. http://www.gsfcarparts.com/parts/engine-parts/crankcase/breather-valve is that the correct part?
Offline doylebros
Re: Where to buy?
« Reply #4 on: September 22, 2013, 01:51:05 pm »
  • -Receive: 427
Re: Where to buy?
« Reply #5 on: September 22, 2013, 02:24:37 pm »
If you can't get to TPS or the dealers then eBay......
Revision N PCV.....
~~ Clicky here ~~
Revision G Diverter valve....
~~ Clicky here ~~
Offline jakex181
Re: Where to buy?
« Reply #6 on: September 22, 2013, 05:55:50 pm »
What about this one as its cheaper, is it the same part? Cheers
 http://r.ebay.com/cnBEIH
  • -Receive: 427
Re: Where to buy?
« Reply #7 on: September 22, 2013, 06:12:37 pm »
Not sure, you'll need the part number.
Offline jakex181
Re: Where to buy?
« Reply #8 on: September 23, 2013, 09:34:43 am »
I have emailed the seller and they have told me that it is an aftermarket part, has anyone got any experience with this? Shall I stick with oem?
Offline jakex181
Re: Where to buy?
« Reply #9 on: September 23, 2013, 10:17:52 am »
Just got an email back from the same guy,  he is now saying I need this http://item.mobileweb.ebay.co.uk/viewitem?itemId=300874390182 that doesn't seem right :/
  • -Receive: 427
Re: Where to buy?
« Reply #10 on: September 23, 2013, 12:53:42 pm »
Stick with OEM PCV or the other option is a PCV revamp kit. Either REVO or BSH for those, around £90 ish IIRC.
Offline jakex181
Re: Where to buy?
« Reply #11 on: September 23, 2013, 12:56:45 pm »
Thanks for the help mate I'm gna go with the oem part you linked
  • -Receive: 427
Re: Where to buy?
« Reply #12 on: September 23, 2013, 01:05:18 pm »
^^^^  :happy2:
