Author Topic: Brake question  (Read 2712 times)
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
Brake question
« on: September 21, 2013, 09:59:20 pm »
Its time to change both front & rear disc's & pads on my my 2008 gt tdi sport 140, my question is i was told its poss got the gti set up as standard due to the age & model does any one know if this would be true.
Im looking at the following options either oem full set from dealers or maybe upgrade set up without spending half my months wages on them :signLOL:. Any help or advice would be great  :happy2:
« Last Edit: September 21, 2013, 10:13:05 pm by mrxbox360 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Brake question
« Reply #1 on: September 21, 2013, 10:24:51 pm »
Your GT will have FN3 brakes
The GTi set up is also FN3 but with larger discs and pads
Cluster and Key coding
Location Great Yarmouth
Offline mrxbox360
Re: Brake question
« Reply #2 on: September 21, 2013, 10:36:26 pm »
hi ed does that mean i should be able to buy the gti disc's & pads without needing to change the caliper's
Offline skard
  • -Receive: 245
Re: Brake question
« Reply #3 on: September 21, 2013, 10:38:21 pm »
Same calipers and pads on a 140, different carriers
Offline nadlad
  • GT Sport 08 140PS
Re: Brake question
« Reply #4 on: September 21, 2013, 11:27:26 pm »
u need my s3 setup mate immense stopping power straight bolt on
Offline Shanny
Re: Brake question
« Reply #5 on: September 25, 2013, 05:11:45 pm »
I also have a golf GT TDi
I purchased a set of original GTI calipers, Carriers, discs and Pads. Fitted straight on without any adjustments or problems.
The Front calipers, Carriers and discs are larger than your standard ones, but i believe the rear ones the calipers and carriers are the same size just the discs are slightly bigger.
Ive only changed my Front ones so far.
Black Golf GT TDI (2004 54)
Edition 30 Front Bumper, Rear Bumper, Exhaust and Rear Lights.
GTI MFSW, R32 Highline Cluster and Gear Knob
Xenon Lights, GT Sport Alloys.
Offline skard
  • -Receive: 245
Re: Brake question
« Reply #6 on: September 25, 2013, 05:15:09 pm »
The 2.0tdi and GTI have the exact same front calipers and pads, only the carriers and discs are different (288v312mm)
Offline Llew
  • -Given: 45
Re: Brake question
« Reply #7 on: September 25, 2013, 05:48:24 pm »
The gti rear discs are larger(286) so you need to change the dust shields if putting onto a tdi
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Brake question
« Reply #8 on: September 25, 2013, 07:07:49 pm »
I only needed to change my carriers to upgrade mine, as skard says, discs are needed too!
Offline Llew
  • -Given: 45
Re: Brake question
« Reply #9 on: September 25, 2013, 07:21:21 pm »
Is that on the rears if so i wasted a few quid when upgrading lol
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Brake question
« Reply #10 on: September 25, 2013, 08:22:58 pm »
Fronts. No idea about the rears!
Offline skard
  • -Receive: 245
Re: Brake question
« Reply #11 on: September 25, 2013, 08:26:14 pm »
I think the rears are the same calipers, just a change of disc and carriers but don't quote me on that!
The fronts I have done on two different cars by just changing carriers and discs.
Offline Shanny
Re: Brake question
« Reply #12 on: September 25, 2013, 11:17:01 pm »
Thanks for the clarification, didn't quiet notice that as i got a full set from someone.
I still have my old ones if anyones interested.
Offline sean140
Re: Brake question
« Reply #13 on: September 26, 2013, 09:42:03 am »
Would this be the same case for a 1.4 TSI 140?
Offline skard
  • -Receive: 245
Re: Brake question
« Reply #14 on: September 26, 2013, 11:37:05 am »
If they have 288mm discs and 55mm struts (as opposed to 280mm discs and 50mm struts) then yes.
