Author Topic: Loose wire help  (Read 454 times)
Offline sean140
Loose wire help
« on: September 23, 2013, 09:17:33 am »
Couple days ago i found this wire had come out of its holding and was catching on the radiator fans. Very nearly ripping through this wire.
I have now secured it with zip ties. Is it safe to have zip ties there? I'm guessing it gets hot there?
Anyways, Does anyone know what that wire is for?
I might change the plastic ties with metal 1's as i'm not 100% confident.
Thanks,
Sean
« Last Edit: September 23, 2013, 11:11:05 am by sean140 »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Loose wire
« Reply #1 on: September 23, 2013, 09:25:23 am »
Looks like some sort of sensor.
Sent From My Samsung S3
Offline sean140
Re: Loose wire
« Reply #2 on: September 23, 2013, 09:50:25 am »
Forgot to add, Its on a 1.4 tsi.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=th6a9s6nlgtcvmt7cfv3om8cob&/topic,19740.0.html
Re: Loose wire
« Reply #3 on: September 23, 2013, 09:52:14 am »
Looks like an exhaust sensor
Offline sean140
Re: Loose wire
« Reply #4 on: September 23, 2013, 10:44:25 am »
It's the wire that is sitting in the silver metal. The long piece running horizontal.
If you zoom in you can see its chopped away at the wire.
