Author Topic: Replacing battery  (Read 15328 times)
Offline Makaveli
Replacing battery
« on: September 23, 2013, 09:30:56 am »
Looks like my battery has died, so I need to replace it. Is there anything I need to do to avoid getting any warning lights after replacing the battery? Also I now need the radio code for my car, is there anyway I can get this without VW charging me for it?
Offline skard
  • -Receive: 245
Re: Replacing battery
« Reply #1 on: September 23, 2013, 09:36:00 am »
If it is already coded you should be ok without needing one.
You will get dash ligts, but should be the usual full turn left & full turn right when stationery, roll forward straight for about 50ft then the lights go out.
Offline Makaveli
« Reply #2 on: September 23, 2013, 09:58:49 am »
Thanks for the reply! I had to jump start it to get it going and it is now prompting for radio code...
Offline Makaveli
« Reply #3 on: September 23, 2013, 11:28:30 am »
Looks like I will need to provide VW with the radio serial number. Is there anyway I can get the serial number of the radio without removing it?
Offline skard
  • -Receive: 245
« Reply #4 on: September 23, 2013, 01:02:42 pm »
VCDS scan or do you have an old log of a scan?
Offline Makaveli
« Reply #5 on: September 23, 2013, 01:32:07 pm »
Unfortunately not, my local dealer seems to think they have to take the radio out to get the serial number and they want to charge me £15 for it! I may as well do it myself but I would rather they get the serial number without having to tak the radio out!
I rang around a few dealers and one is happy to provide me the radio code free of charge but I need to provide them with serial number first, the other dealers want to charge me for providing the radio code!
Offline skard
  • -Receive: 245
« Reply #6 on: September 23, 2013, 01:37:36 pm »
It is a 5 minute job to remove the stereo if you have a torx screwdriver
Offline Makaveli
« Reply #7 on: September 23, 2013, 06:19:40 pm »
Thanks skard, I will give it a go myself. Im driving around without music at the moment and im missing it! :jumping:
Offline Makaveli
« Reply #8 on: September 26, 2013, 04:03:57 pm »
Can someone let me know in terms of amps etc what I should be looking out for? I picked up a battery from my local VW dealer for around £70 but another dealer quoted me around £130 so want to make sure I put in the right type! Its for a MK5 Golf GTI.
Offline skard
  • -Receive: 245
« Reply #9 on: September 26, 2013, 04:47:38 pm »
I have a 70Ah 340A battery made by Varta, 1J0915105AE
Offline Makaveli
« Reply #10 on: September 26, 2013, 06:12:00 pm »
Right... I got the new battery home and its smaller than my current one so im definately not sure I have the right one. I have detailed the battery details below (not sure which number/letters you need so have detailed them all) if someone can help :ashamed:
Current battery details:
VARTA
12v 72Ah 380A DIN
640A EN/SAE
New battery details:
Part number: JZW 915 105
12v 61Ah 540A EN/SAE/GS
300A DIN
Any help would be appreciated! :drinking:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Offline skard
  • -Receive: 245
« Reply #12 on: September 26, 2013, 06:46:08 pm »
Yep, get a battery with a higher or at least the same rating as currently. Don't keep the one provided!
Offline Welshman Adam
Re:
« Reply #13 on: September 26, 2013, 06:47:25 pm »
I replaced mine last weekend. £53 inc VAT for an Exide Excell from TPS. 3 year warranty and it's a slightly better spec than the Varta that is standard fit. 71ah I think it was.
I have the MFD2 in my car and had no coding problems after changing the battery.
Black ED30 No. 1,328 - Gone but not forgotten...
Offline Makaveli
« Reply #14 on: September 26, 2013, 06:59:12 pm »
Thanks for the replies! So the important bit to check with them is the Ah part? e.g. 72Ah, the higher the better? Do the other letters/numbers need to be checked?
Im glad I didnt fit the battery now! :pomppomp:
