November 24, 2024, 07:24:57 pm
All Things Mk5
Mk5 General Area
Aircon fault codes?
Topic: Aircon fault codes? (Read 960 times)
Andy1994
Always Involved
-Given: 2
-Receive: 4
Aircon fault codes?
September 24, 2013, 11:39:29 pm »
Refrugent pressure low, system is full with gas and no leaks, does this code refer to the pressure switch or is it more likley faulty compressor, all fuses ok etc...
any help would be great thanks
http://www.mk5golfgti.co.uk/forum/index.php/topic,70370.0.html
Andy1994
Always Involved
-Given: 2
-Receive: 4
Re: Aircon fault codes?
Reply #1 on:
September 25, 2013, 10:37:58 am »
Anyone?
ROH ECHT
Just look at my post count
-Given: 113
-Receive: 149
K04 PLAY....ZOOM DIS!
Reply #2 on:
September 25, 2013, 10:40:12 am »
Your code was???
K04 PLAY...K04 turbo/S3 INJ. & FMIC/FORGE FMTC, TB hose, & WG actuator/GIAC's H.O. K04 & DSG TUNES/AWE DV/NEUSPEED P-FLO,TURBO OUTLET & TB pipe/AUTOTECH hpfp/BSH Eng.&Trans Mounts/H&R ARB's/Whiteline Performance springs & W.A.L.K./ECS stage-3 BBK/BILSTEIN B8's...ZOOM'DIS...GIAC K04 tune-2007 Volkswagen GTI: 12.823 @ 112.050 MPH__Voting for my Dragtimes link:
http://www.dragtimes.com/Volkswagen-GTI-Timeslip-25700.html?r=1
Andy1994
Always Involved
-Given: 2
-Receive: 4
Reply #3 on:
September 25, 2013, 12:58:47 pm »
Refrigerant pressure low
Andy1994
Always Involved
-Given: 2
-Receive: 4
Reply #4 on:
October 01, 2013, 10:51:42 pm »
still looking for help on this, i have access to vagcom so is there anything i can check to see if its the sensor or the comprssor
Andy1994
Always Involved
-Given: 2
-Receive: 4
Reply #5 on:
October 28, 2013, 07:28:37 pm »
bump, checked using vagcom with no codes found relating to aircon but using launch diagnostic i have a code for refrigerant pressure low but the system is full. so does anyone know if the fault lies with the compressor or the switch?
doylebros
-Given: 44
-Receive: 309
Reply #6 on:
October 28, 2013, 07:35:45 pm »
You can run the Aircon system with VCDS & log compressor current draw etc using measuring blocks or run an output test!
However, the pressure switch is a very common problem.
pd9264
Always Involved
-Given: 11
-Receive: 7
Reply #7 on:
October 28, 2013, 08:09:03 pm »
I had this and it was pressure switch. Just unscrew and fit new or. It screws onto a Shrader valve
Andy1994
Always Involved
-Given: 2
-Receive: 4
Reply #8 on:
October 28, 2013, 09:30:35 pm »
shall try that then, windows misting up is driving me mad
All Things Mk5
Mk5 General Area
Aircon fault codes?
