Author Topic: sudden drain battery drain(HELP)  (Read 2853 times)
Offline Llew
  • -Given: 45
Re: sudden drain battery drain(HELP)
« Reply #15 on: September 25, 2013, 05:32:27 pm »
If both are sound then look to the starter motor
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline eltel
« Reply #16 on: September 25, 2013, 06:57:10 pm »
starter motor is ok,it is roughly draining by 3 amps when i take out fuse f19 the loss is 0.5 amps so it is still draining from somewhere?????
Offline Llew
  • -Given: 45
« Reply #17 on: September 25, 2013, 07:26:28 pm »
Have you rebooted the rns?
Offline eltel
« Reply #18 on: September 25, 2013, 07:33:12 pm »
i have re booted it
Offline Llew
  • -Given: 45
« Reply #19 on: September 25, 2013, 07:44:32 pm »
I am down your way on Saturday (airport pickup) if you want and can wait I can put it on vcds and if no joy I can lend you my rcd300 for awhile so you can at least be certain wether it's the rns or not
Offline Llew
  • -Given: 45
« Reply #20 on: September 25, 2013, 07:58:31 pm »
Or you can unplug the rns for a while and see what happens
Offline eltel
« Reply #21 on: September 25, 2013, 11:02:28 pm »
Cheers llew
That would be great, I don't want to put you out though. Pm me :happy2:
Offline Llew
  • -Given: 45
« Reply #22 on: September 25, 2013, 11:50:34 pm »
No put out at all I have to go pickup misses from southend on Saturday  so i will be near there pickup time is 9pm so i can reach you about 7.30pm my number is 07946182007 Leo
Offline Llew
  • -Given: 45
« Reply #23 on: September 25, 2013, 11:51:11 pm »
Oops I thought that was a pm
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #24 on: October 05, 2013, 02:02:58 pm »
Terry came to me today and I can add more info
Gateway is not the Problem as his Gateway was a 1K0907530L and  the RNS doesn't go into sleep mode
I tried a newer AF gateway, different RNS and new ignition switch all made no difference to the draw on the RNS
There were several faults with the locking system and one in the steering ignition switch (why I tried a new switch)
I'm thinking it is to do with the locking system why the RNS doesn't shutdown
Cluster and Key coding
Location Great Yarmouth
Offline Cupra R
  • -Given: 18
« Reply #25 on: October 05, 2013, 02:55:43 pm »
Eddie
How did you check if the RNS was going to sleep or not?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #26 on: October 05, 2013, 03:06:54 pm »
by locking the car with the remote (switching the bonnet catch before)
then using a Multimeter on mV setting and checking the fuse for the RNS
I tested it on my car and after around 10mins would show 0.00mv
on this car it stayed the same even after nearly half an hour
Offline Cupra R
  • -Given: 18
« Reply #27 on: October 05, 2013, 03:15:49 pm »
Cheers Eddie
I'd like to test my car out for this but I don't know how to do the bonnet catch trick  :ashamed:on a Seat Leon.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #28 on: October 05, 2013, 03:21:02 pm »
simple
use a screwdriver to push the lever till it locks
check the dash so that it shows as closed
I then release it with the lever before closing it when finished
