Author Topic: Glove Box question  (Read 708 times)
Offline jamma
Glove Box question
« on: September 27, 2013, 08:09:39 am »
Hi – question regarding the glove box, when you close the glove box how does the light switch off? Is it that button that you can press just under the light? I just tried pressing that and my light doesn’t go off.
Just trying to work out my batter drain problem?
Offline SI-R32
  • -Receive: 125
Re: Re: Glove Box question
« Reply #1 on: September 27, 2013, 08:24:32 am »
The switch is at the back of the glove box in the middle, when its open you should be able to put your hand behind the lid and feel around,
Alternatively if you pop off the trim at the end of the dash you can see the light going on and off so no need to find the switch.
Offline jamma
« Reply #2 on: September 27, 2013, 08:54:46 am »
ah ok cheers, wonder what that button is then near the light!
