Author Topic: How to remove drop links?  (Read 4487 times)
Offline woahnowboys
« on: September 27, 2013, 03:22:09 pm »
Had some coilovers fitted recently, and am trying to remove them for a bit of tidying..
How do the drop links unbolt from the suspension?
I've read that it just unbolts with a 19mm ratchet, but I'm sure the bolt keeps spinning..
Does the thread/bolt need to be held while I turn the nut?
thanks! :popcornsoda:
'87 MK1 Cabby - To be 20vT'd.
MK5 Daily.
Instagram - woahnowboys
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=7rdcjocq40n348akn8a1fgs82i&/topic,19740.0.html
Re: How to remove drop links?
« Reply #1 on: September 27, 2013, 03:25:10 pm »
You need a spline bit to put in the centre of the bolt to stop it rotating. M8 maybe
Offline xjay1337
  • -Receive: 377
« Reply #2 on: September 27, 2013, 03:44:40 pm »
You can hold the head with some mole grips but it's properly pikey.
You need a multispline tool I think it's an M12 for some reason.
Or a 12 spline thingy .
Offline woahnowboys
« Reply #3 on: September 27, 2013, 06:47:53 pm »
Just went to Halfords and B&Q, all they had between both shops was a £35 set of four multispline sockets.. :stupid:
I'm thinking the ghetto method is next. :sick:
Unless I could get a torx socket to fit well enough in there?
MK5 Daily.
Offline xjay1337
  • -Receive: 377
« Reply #4 on: September 28, 2013, 12:57:49 am »
I think I used a T50 torx in the past (or 60 can't remember) but again that's a pikey method lol and you risk rounding the bolt off. Then you're screwed if you ever need to change susp or can't get it tight!!
