Author Topic: Intake manifold runner?  (Read 15731 times)
Offline mk4gti-t
  • -Given: 61
« on: September 30, 2013, 01:58:08 pm »
Ive got an intake manifold runner control fault which could be causing me to get a lumpy idle when starting my car. Does anybody have any info on this and where it is located? Also what does it do? My fault is saying basic settings aborted - mechanical flap shut? Cheers.
Re: Intake manifold runner?
« Reply #1 on: September 30, 2013, 03:34:54 pm »
If you have a vcds cable the try doing the basic setting
Prerequisites:
 Ignition ON
 Engine OFF
 System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
 Group 142
[Go!]
 Activate the Basic Setting.
[ON/OFF/Next]
 Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
 Switch Ignition OFF for at least 60 seconds.
Offline mk4gti-t
  • -Given: 61
« Reply #2 on: September 30, 2013, 03:51:01 pm »
I've tried the basic settings and get the error again at step 30 of the process?
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: September 30, 2013, 07:46:01 pm »
Unplug the motor, turn on the ignition, turn off the ignition, plug back in, clear codes, run adaption.
Give that a shot.
Follow AKS tuning on Facebook
Offline mk4gti-t
  • -Given: 61
« Reply #4 on: October 01, 2013, 06:09:05 pm »
Cheers i'll give it a go tomorow. Any pointers to the exact location of the motor please  :signLOL:
« Reply #5 on: October 01, 2013, 06:20:34 pm »
This view of the tumble flap actuator is from the underside of the intake manifold.
Offline mk4gti-t
  • -Given: 61
« Reply #6 on: October 01, 2013, 06:23:22 pm »
Could this be causing my lumpy idle on start up? It only lasts about 2-3 seconds.
Saintsteve
« Reply #7 on: October 01, 2013, 06:38:34 pm »
You might have the makings of a failing injector.
Run logs and check for live idle mis- fires on each cylinder
« Reply #8 on: October 01, 2013, 07:16:08 pm »
It could be...
If you run the output test in vcds for the motor you'll be able to see if the actuator arm is sticking or not by looking at it.
Offline mk4gti-t
  • -Given: 61
« Reply #9 on: October 01, 2013, 07:50:30 pm »
Great thanks for the advice once again.
Is the output for this found in Engine controller?
« Reply #10 on: October 01, 2013, 08:06:05 pm »
open vcds>engine>output test 03
then select Intake manifold flap from the drop down list
While the test is running the actuator arm should move to fully open and close the flaps
Offline mk4gti-t
  • -Given: 61
« Reply #11 on: October 01, 2013, 08:08:16 pm »
Thank you once again....................... :happy2:
Offline mk4gti-t
  • -Given: 61
« Reply #12 on: October 02, 2013, 02:32:24 pm »
Right ive looked at the actuator rod and it doesnt move when tested with vcds. I can move it down and back up freely byhand but when testing the output it moves upwards slightly then just doesnt go any further?
Could something be jaming it?
« Reply #13 on: October 02, 2013, 03:45:54 pm »
I'm no hardware expert but I suspect your flapper motor unit needs changing.
« Reply #14 on: October 02, 2013, 03:56:59 pm »
Found a DIY for you if you plan on doing this yourself.
http://www.audizine.com/forum/showthread.php/306032-DIY-Intake-Flap-Motor-Replacement
Please note that if your unit has a letter on the end of its part number (mine was 06F 133 482B) then get the latest E version. VW will want a little over £180 for one. If your unit has no letter on the end of its part number i.e. 06F 133 482 then you need to replace it with the same part number.
