Author Topic: rethreading plastic  (Read 1304 times)
Offline sootpig
rethreading plastic
« on: October 01, 2013, 08:27:13 pm »
Need a couple of plastic holes re threading. will an epoxy filler do the job or is there something better
       Thanks in advance  :drinking:
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: rethreading plastic
« Reply #1 on: October 02, 2013, 12:13:06 pm »
Helicoil?
Offline DDM
« Reply #2 on: October 02, 2013, 06:26:56 pm »
you could try warming the bolt/screw you intend to use on the piece of plastic, ie warm it up and wind it in and leave to cool,
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: October 02, 2013, 06:34:24 pm »
Easiest and quickest way is to fire epoxy into the hole and screw the screw into it. Once it sets you should be able to wind it tighter against the part you are holding in.
Pcv valve by any chance?
Follow AKS tuning on Facebook
Offline sootpig
« Reply #4 on: October 02, 2013, 06:47:33 pm »
This worked with PTFE tape wrapped around the threads  Thanks for the replies  :happy2:
