Author Topic: WTF - Tech Note on service - Lower Turbo Pipe Leaking  (Read 11694 times)
Offline nc35
  • -Given: 40
Re: WTF - Tech Note on service - Lower Turbo Pipe Leaking
« Reply #15 on: September 04, 2009, 02:30:36 pm »
Well - I really have no idea...
Are any of the other bits availbe?  And how much?
One of the other posts said that OEM wasn't very good.
Also where are you?  Can possibly collect and pick your brains as to installing them...
Lee
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
« Reply #16 on: September 04, 2009, 02:51:47 pm »
@ Lee:
What my pic is showing is the new parts (now fitted on my car) alongside the stock parts. I took the pic to show people a comparison.
The only parts I may be willing to consider selling are the stock parts but I'm slightly inclined to keep the hoses as emergency spares as SAMCO take so long to get.
Offline nc35
  • -Given: 40
« Reply #17 on: September 04, 2009, 05:49:42 pm »
Ooops sorry  :ashamed:
I had better start looking for a hose set
Thanks for your help  :happy2:
Lee
No Golf anymore.
Thank You Everyone.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #18 on: September 04, 2009, 05:55:35 pm »
I wouldn't be too hasty to splash out on the pipe Robin displays as for one they all rely on you taking the O seals from your current setup to fit to them and secondly they connect in much the same manner as the OEM ones.
Don't get me wrong they have their place, I ran the Neuspeed outlet pipe for a while with some good results but it's a lot of dollar to be splashing out in one hit.
Stu...
« Reply #19 on: September 04, 2009, 06:09:16 pm »
....I agree with you Stu.
Generally I think that most Neuspeed products don't deliver much extra. However, for whatever little it's worth, the SAMCO ally connections are top notch and so is the quality of their silicone hose construction.
I didn't have any logging done but the engine did feel as if it was freer revving after the installation. Placebo?
Anyway, you know how much I don't mind splashing out money. There's no point me having regrets and I'm glad of the SAMCO bits.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #20 on: September 04, 2009, 07:13:00 pm »
I wasn't trying to say the products aren't good simply trying to say in this case it might not be ideally suited to the OP's needs.  FWIW I thought after fitting the Turbo Outlet that it had made an improvement.
I like the Neuspeed stuff, some of it is on a par with APR in terms of quality.
Stu...
« Reply #21 on: September 04, 2009, 08:46:09 pm »
....Well, I didn't find much of an improvement after fitting these particular Neuspeed components on my particular car, other than a slightly freer revving engine as I said - Certainly not the degree of improvement that their blurb suggested. Quite expensive too. But at least I am confident my boost hoses are more durable.
Neuspeed stuff might be ok in terms of quality but personally I would always also check what other brands offer the same before buying in the future. Our purchasing decisions all come down to our individual experiences.
Offline Tarmac_Terrorist
« Reply #22 on: September 04, 2009, 08:57:49 pm »
....Which is why I upgraded all my turbo piping as a precautionary measure. VW, and others, don't manufacture their cars to accommodate aftermarket tuning.
I was under the impression that VW built in some sort of additional stress / tollerance margine of 30-40% into their products. If that's the case you may expect the oem products to withstand moderate performance increases.
« Reply #23 on: September 05, 2009, 10:09:13 am »
....Yes, I've been told the same - Approx +40% headroom - Not an exact science though. I guess it's a major contributor to that reputation of strong build. However, it won't be applied to every single one of the zillion components which VW use in manufacturing a car.
Regarding the turbo piping, what I have done will doubtless have increased the tolerance headroom waaaay beyond any +40% (I'm running between 240-270bhp according to which rolling-road), but I happened to get offered some SAMCO hoses and then decided I may as well add the Neuspeed Turbo Charge and Discharge pipes. It was one of those totally unplanned mods - Rather random.
« Last Edit: September 05, 2009, 10:11:31 am by RedRobin »
Offline nc35
  • -Given: 40
« Reply #24 on: September 05, 2009, 05:22:26 pm »
Just to update
had the engine cover off today and no sign of a leek anywhere
don't really know what to look for water/oil or signs of.
Can't see anything at all to be a worry.
But the front left bracket for the cover was nearly off bolt nearly out,
and only one screw in the air intake at the front.
Less and less impressed with dealer mechanics.
Going to post else where, but any suggestions for a indie up north?
Perferably West Yorks / poss Manchester
No Golf anymore.
Thank You Everyone.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #25 on: September 05, 2009, 05:34:02 pm »
I think the leak in question would be low down on the drivers side near the wheel arch.  Visible from underneath.
Stu...
« Reply #26 on: October 23, 2011, 11:36:19 pm »
Bit of a resurection but...
Robin, would you say the Samcos with ally ends are less prone to the oring failure found on mapped cars?
« Reply #27 on: October 24, 2011, 08:32:32 am »
....G'morning, daddy!
I think so. Although expensive (and the Forge are probably just as good if they are lined), the SAMCO hoses are top-notch quality construction. Even when I ran over something sharp and a lower hose was cut it didn't leak. A remapped car will be putting through more pressure and although I haven't heard of splits/failures on the OEM Mk5 GTI's turbo hoses it was apparently quite common on the modded Mk4's.
If you fit some, go for stainless steel jubilee clips - No need to spoil a ship for the sake of a halfpenny worth of tar.
They certainly give peace of mind and extended life. The OEM appear somewhat naff by comparison. Not cheap though.  :happy2:
« Last Edit: October 24, 2011, 08:34:36 am by RedRobin »
« Reply #28 on: October 24, 2011, 08:37:12 am »
Mornin  :wink:
Thanks for your reply ;)
I didnt see my boy all day yesterday for sorting the house for an inspection that should be happening now, housing officer hasnt turned up.  Cheers  :fighting:
Did I miss where you sourced yours from?  Samco Direct? Cost?  I think Awesome do the Forge turbo hoses but I will compare reviews and prices  :happy2:
thanks again
Mike
« Reply #29 on: October 24, 2011, 08:39:07 am »
I've now added pics to my previous post.
PM incoming re 'source'.
