Author Topic: WTF - Tech Note on service - Lower Turbo Pipe Leaking  (Read 11701 times)
Re: WTF - Tech Note on service - Lower Turbo Pipe Leaking
« Reply #30 on: October 24, 2011, 08:56:27 am »
Next engine mod (and probably last before funds dry right up!) will likely be the forge turbo hose kit and the Neuspeed Discharge pipes
Although Ive heard negative comments about theForge throttle body pipe & the OEM one does the job.
Thanks for the Pics Robin  :happy2:
« Reply #31 on: October 24, 2011, 09:55:05 am »
....I'm naturally interested to know the negative comments.
This overall mod including Neuspeed pipes is not the sort which will have an obvious benefit and cause you to exclaim "wow!".
« Reply #32 on: October 24, 2011, 10:04:52 am »
Nothing to seriously put me off fitting it, going out the door will update and give you a nudge ;)
