Author Topic: WALK kit bushes worn out replacements??  (Read 3229 times)
Offline vag12
« on: October 05, 2013, 01:44:09 pm »
Just wondering if anyone can help me out? My car is stuck at r tech and can not be mapped as the walk kit bushes have worn causing excessive movement, does anyone know if the poly flex bushes will be a direct replacement and if so will the walk kit still keep the same characteristics it is meant to have?
Wanting to replace with these:
eBay part number:
110919910667
Offline vag12
Re: WALK kit bushes worn out replacements??
« Reply #1 on: October 05, 2013, 01:47:18 pm »
Prompt reply will be highly appreciated as need to order the parts ASAP
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: October 05, 2013, 03:53:44 pm »
Superpro front wishbone rear bush. Better quality too  :happy2:
Offline vag12
« Reply #3 on: October 05, 2013, 03:58:05 pm »
Thanks mate I have ordered from the eBay item number above so that should again do the job right? And do you know if the functions of the WALK kit will remain the same?
Offline nicky
« Reply #4 on: October 05, 2013, 09:45:00 pm »
How old is the walk ?
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: October 05, 2013, 10:11:57 pm »
Don't get the Superpro press in bush. Only go for the full console kit they do. Aloy3273-80k iirc.
Follow AKS tuning on Facebook
Offline vag12
« Reply #6 on: October 05, 2013, 11:54:35 pm »
Can't I just get the polyurethane part which goes inside the part and insert in to the WALK brackets?
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: October 06, 2013, 08:11:14 am »
The standard superpro press in bush may not fit in the whiteline brackets.  The press in bush isn't as strong as the full console.
Offline vag12
« Reply #8 on: October 06, 2013, 01:55:53 pm »
No sorry I was talking about the polyflex ones, basically the eBay item number I have given in the original post?
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: October 06, 2013, 02:36:53 pm »
Tbh you won't know until you try.
Offline vag12
« Reply #10 on: October 06, 2013, 03:28:28 pm »
Alright thanks anyway
