Author Topic: RNS 510 - Faulty Volume Knob [NEED HELP]  (Read 8451 times)
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« on: October 06, 2013, 06:01:03 pm »
Hi everyone,
The volume knob on my RNS 510 is faulty. The unit came with the car when I bought it and the guy told me about the problem, so I was aware of this, but it is starting to get annoying now   :sad1:
Basically when I adjust the volume, instead of it just going up, or just going down like it should, it goes up down up down up down up down, so it ends up on the same volume. The way to make it work properly is to push it down and to the left at the same time, and then turn it. It's rather fiddly.
The knob doesn't physically feel loose, so not sure what to do. Has anyone ever had this problem?
Thanks!  :happy2:
Instagram @george_kersh
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
Re: RNS 510 - Faulty Volume Knob [NEED HELP]
« Reply #1 on: October 06, 2013, 06:12:49 pm »
id try a factory reset 1st
Offline Georrge
« Reply #2 on: October 06, 2013, 06:15:10 pm »
Hmmm, the fact tat it will work if held in a certain position makes me think it's defiantly a hardware issue rather than software
Offline ARV_90
« Reply #3 on: October 07, 2013, 10:29:29 am »
Is your car DSG with paddles ?  It might be easier to fit the buttons to the steering wheel  :smiley:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: October 07, 2013, 02:15:30 pm »
It could be a problem with the plastic dial or the hardware soldered on to the PCB
You are going to have to take it apart to find out
Cluster and Key coding
Location Great Yarmouth
Offline Georrge
« Reply #5 on: October 13, 2013, 12:00:03 am »
Manual. I would absolutely love a multi function steering wheel though, but as far as I know they are for DSG models only?
Offline Georrge
« Reply #6 on: October 13, 2013, 12:01:06 am »
Thank you, I'll have a search online to see if I can find anything about taking one apart. I don't feel confident with going into this blind  :scared:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #7 on: October 13, 2013, 05:51:24 pm »
Manuals can have MFSW too
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #8 on: October 13, 2013, 06:50:55 pm »
If the volume button is screwed its not too hard a job to replace. Get this and remove the volume knob and screen board - job done :)
http://tinyurl.com/qg5m8bc
Offline doylebros
« Reply #9 on: October 13, 2013, 07:06:58 pm »
Offline Georrge
« Reply #10 on: November 16, 2013, 02:33:01 pm »
Thanks every one for the help and advice, this seems like everything I need to sort it out  :smiley:
Offline Adam-golf
  • Derv!
« Reply #11 on: November 20, 2013, 10:01:01 am »
I have a similar issue on a rcd510 but it occasionally works. Would it be the same fix?
« Last Edit: November 20, 2013, 10:13:26 am by Adam-golf »
Offline Georrge
« Reply #12 on: May 04, 2014, 09:50:58 pm »
Digging back this old thread because the problem was never fixed, and it's now really starting to annoy me  :sad1:
This listing was only for a single button, it wasn't for the board as well :(
Does anyone have any idea if taking it apart and soldering something will fix it?
Offline jamie
« Reply #13 on: May 05, 2014, 06:38:22 pm »
Hi mate,
I've just taken the rns-510 out of my car and at first I thought it might be a bit of a task...but if you work slowly and have patience it should be ok.
Have you removed it from the car?
Offline Georrge
« Reply #14 on: May 05, 2014, 07:56:29 pm »
Hi mate,
Taking it out the car is easy enough, have done it a few times in the past. Taking it apart is another story though.. :grin:
