Author Topic: wheel sensor part number  (Read 2795 times)
Offline bower
« on: October 07, 2013, 05:50:34 pm »
does any one know what the part number is for the wheel sensors please also are they easy enough to replace?
thanks
Offline doylebros
Re: wheel sensor part number
« Reply #1 on: October 07, 2013, 07:37:32 pm »
Do you mean ABS sensor if so watch this
http://m.youtube.com/watch?v=6C4bFzSw_zg
Then come back.
Offline bower
« Reply #2 on: October 07, 2013, 08:35:10 pm »
yeah the abs sensor,  ive watched that already. i had it scanned today and apparently its its the rear left sensor but cant find the part number
Offline doylebros
« Reply #3 on: October 07, 2013, 09:21:42 pm »
I would still do the multimeter test on the sensor, as the ring on the hubs are common for corroding away and giving the same fault.
Offline bower
« Reply #4 on: October 07, 2013, 11:45:06 pm »
i will do pal cheers for your advice  :happy2:
Offline bower
« Reply #5 on: October 08, 2013, 08:22:57 am »
right ive done that and the sensor isnt coming back as its dead, but when its on vagcom its showing the speeds all over the place. so is it more likely to be the hub?
Offline doylebros
« Reply #6 on: October 10, 2013, 08:26:01 pm »
You really have to remove the disc but the hub is favourite for the ring corroding and giving that fault.
Part no:- 1T0 598 611 subject to year and diameter remark if it's the hub!
Price TPS £130.39 inc vat but full retail.
Sensor part No :- 1K0 927 807 - supersession to WHT 003 859 - price TPS £72.95
« Last Edit: October 10, 2013, 08:47:19 pm by doylebros »
