Author Topic: Canbus gateway  (Read 811 times)
Offline al200
Canbus gateway
« on: October 07, 2013, 06:08:10 pm »
I am in the process of upgrading my headunit to a rcd510 and found out that I have to upgrade the canbus gateway due to issues with battery drain.
Im looking to get one from ebay for about £40 but can't tell if they are the right revision as the model numbers vary completly. I know I need revision L or above but how do I know its the right one from the model number. The ones I have found have the following codes:
7N0907530R
1K0907530F
Will either of these solve the battery drain issue?
Thanks for any advice.
Offline al200
Re: Canbus gateway
« Reply #1 on: October 07, 2013, 09:27:34 pm »
Anyone shed any light on this?
Offline skard
  • -Receive: 245
Re: Canbus gateway
« Reply #2 on: October 07, 2013, 09:35:03 pm »
The one starting 1K0 is where you need L or later.
The 7N0 part is a later model so all of them are ok.
Offline al200
Re: Canbus gateway
« Reply #3 on: October 07, 2013, 09:42:06 pm »
Thank you!  :happy2:
