Author Topic: Common Problem fixes  (Read 983 times)
Offline jakex181
« on: October 08, 2013, 03:41:00 pm »
Ive been looking at the Mk5 GTi common problems and have recently replaced my PCV making an improvement, Im not sure if my DV is damaged and i am not aware of it being replaced in the cars life, is it worth me buying a new one and replacing it anyway? If so which revision is best to go for as ive seen some people dont choose the latest one.
Also id like to check my cam follower but was thinking am i better of just replacing it aswell while im checking, im not a mechanic but im an engineer, is this something that is easy to do myself?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Common Problem fixes
« Reply #1 on: October 08, 2013, 03:53:56 pm »
I'm certainly no mechanic either mate, but have replaced DV and Cam follower, if you take your time, esp. on the latter they are simple jobs really... worth noting, opening the drivers door will prime the fuel pump. :evilgrin:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: October 08, 2013, 04:49:34 pm »
There are guides on cam follwer change (including a video) here - http://www.mk5golfgti.co.uk/forum/index.php/topic,52731.0.html
It's an easier job with 2007 cars and younger, but is by no means insurmountable on older models.
It would be well worth checking your DV. Revision G is the best replacement.
'07 Red manual
Offline jakex181
« Reply #3 on: October 08, 2013, 09:41:16 pm »
Cheers guys will get both on order ASAP
